The H3 just went over 150,000 miles but was definitely due for some maintenance. It's been an active and $$$ few months but overall I'm happy because the H3 is happy
- ACDelco serpentine belt, tensioner pulley/bolt, and idler pulley
- ACDelco iridium spark plugs
- Cleaned mass air flow sensor and throttle body
- Broken exhaust manifold bolt extraction (x3)
- GM exhaust manifold, gasket, and stud replaced
- Third brake light replaced, great write up can be found here
http://www.hummer4x4offroad.com/forum/showthread.php?6364-Hummer-H3-Third-Tail-Light-Repair-Mod
- ACDelco crankshaft seal and harmonic balancer kit w/washer and bolt
- Transmission cooler lines and fittings replaced (small leak)
I do have a few more upgrades planned before Oct when my friends and I will be in Moab. BTW PM me if you're interested in joining us in Moab, last year we had 8 suv/trucks and around 6 atv/utv's in attendance. Anyway, here is the list of future upgrades before Oct;
- Outfitter Design steering rack kit and front differential bushings
- ACDelco expansion valve kit
- ACDelco CV axle and seal (driver side). I've had a minor front differential fluid leak for over a year that I'd like to finally fix that I suspect may be fixed by replacing these parts.
