Derian06, I had the same thoughts as you about the exo cage. I don't want a full cage like I've seen on some Jeeps, but I like the ideas you've mentioned. Can't wait to see you put your ideas into metal!
Now I really like that idea! Having the option to close during the wet times would be nice. Finding a good looking louver is hard or way over priced so if you came up with a nice one that looks oem at a good cost would be pretty high on my list to get.I have been debating on cutting holes in my hood and making the nonfunctional Louver functional. That being said a kit to mount to the underside of the hood with a manually adjustable set of gates to close her up and minimize water intrusion during the winter months would be cool. It'd just be nice to vent the engine compartment on the hot summer crawls.
This can be found and made yourself pretty easily without spending a ton if you are willing to make it yourself. Get a set of generic louvered vent panels and trim to your liking (like these: http://www.zoro.com/hoffman-louver-plate-kits/g/00233235/ ), a push/pull choke cable (Dorman P/N 55195 is $10.75), an appropriately sized rectangle or two of aluminum sheet (Lowes, Home Depot), some DIN rail material to cut to the length of the hole in the hood to hold the aluminum plate up tight. Add some automotive felt edge seal or 1/4" strips of the loop side of some velcro glued onto edges of the aluminum to make the piece slide easily but still seal well. Run the choke cable through the firewall up to the aluminum plate to pull it clear and push it closed. Just stay away from self-tapping screws, brown speaker wire and black electrical tape...those make it look like poo. Do it cleanly and everyone will ooh and ahh at your craftsmanship.See, and all I'm talking about is a close blue vent kit with a flange around the edge to pop rivet to the underside of the hood. Then we can cut the hood ourselves, install mesh, and modify the stock plastic Louver with vent slots.
yes, I could make them myself. And might. But the point of this thread was voicing ideas of kits we would like available...This can be found and made yourself pretty easily without spending a ton if you are willing to make it yourself. Get a set of generic louvered vent panels and trim to your liking (like these: http://www.zoro.com/hoffman-louver-plate-kits/g/00233235/ ), a push/pull choke cable (Dorman P/N 55195 is $10.75), an appropriately sized rectangle or two of aluminum sheet (Lowes, Home Depot), some DIN rail material to cut to the length of the hole in the hood to hold the aluminum plate up tight. Add some automotive felt edge seal or 1/4" strips of the loop side of some velcro glued onto edges of the aluminum to make the piece slide easily but still seal well. Run the choke cable through the firewall up to the aluminum plate to pull it clear and push it closed. Just stay away from self-tapping screws, brown speaker wire and black electrical tape...those make it look like poo. Do it cleanly and everyone will ooh and ahh at your craftsmanship.
This fall/winter I think I will make an aluminum plate the size of the holes in the hood and hold them in place with rare earth magnets above and a strip of steel from above under my hood louvers to keep the heat in and weather out.
I think those are really cool, definitely would buy
I don't know everything about how our front differentials are, BUT..
Would it be feasible to fabricate parts that allow us to bolt on an existing aem differential? A unit with higher gearing so we can match it at the rear diff.
I'd cancel my plans for an expensive (and illegal) engine swap![]()
How about some high clearance rock rails? Strong, and relatively light (50lbs each). Won't rub the back of your pant let when climbing in or out of the truck.
Thanks for that! I guess I'll be doing that engine swap end of the year.
The OEM sliders leave an unattractive gap when the daystar body lift is installed. Would be nice to close that gap as an option with these.
I believe that 1" gap is perfect as it gives some space before the slider grabs onto the body in hard hits.^^agree, i'd be willing to trade or sell the oem ones if that were an option.
