TAPDH3T
- Texarkana, Texas
Where did you get the spacer from?
I still didn't answer your question lmao... I got em off eBay!!!
Great idea. I am interested and will be following this thread for any updates. Let me know how it works out.
YES. You can tilt the nose of the front axle like that because the driveshaft has a CV on the other end of it. However, don't do this if you are running standard u-joints on both ends...it puts them out of phase with each other and causes vibes.
What is going on with your front suspension? Is that a Rancho center bracket with (gulp) GM knuckles? You should get a spare steering rack and have it standing-by. You'll need it running that much angle on the tie rods.
All depends on the diesel! A D44 is perfect for a 4bt...if you are looking at a 6bt or a Duramax, then go for the D60.
The bulk of work for a SAS is done whether you are running a dana 44 or 60. If you wanna upgrade or downgrade later it would be relatively easy. You rebuild the axle with the same brackets then you swap out the axle in a few hours. Not too hard.
I haven't seen anyone run chromos in the rear yet.
Money is burning a hole in my pocket!
Just curious. How did you get three-fourths of a Rancho lift? Where are the knuckles that are supposed to be with it? They are arguably the most important part of the kit.
Yes, because stock is 22.5 so 1.5in over would be 24 and 26.5-27 plus 1.5 is 28-28.5
Lmfao the lightning in the background is a great touch [emoji23][emoji23]
