skinner41
- North central Nebraska
I have a 2010 H3T 3.7 with 315/75r16 and wondering what kind of tuner would be the best.I have looked at bullydog but could not find any that would fit.Thanks
Damn it they didn't have one listed for 06/07 but in 08 they switched the electrical systems correct?
The data protocol switched to CAN in 08 and I believe the ECM and TCM were combined in to one unit.
Dang man. You seem like you really tweaked everything... I wonder how that compares to my tune. Are you able to save your configurations and flash them to anyone's pcm.... The altitude may have a little different effect on how your truck performs with it vs someone else's at a different altitude...
the hptuners allows you to compare all the changes with the original stock file. so if a flash can't be done (due to diff VIN) you can copy the parameters and edit your tune manually.
However, the hptuners tune file is very vehicle specific (esp if he fine tuned it on his truck) meaning that it has to be fine tuned on ur truck to get you the best results.
Btw the altitude has a great effect because of the amount of oxygen in the air (you may be getting more or less air depending on the difference) and this results in different timings, etc... which means that your truck would need to be fine tuned diff than his.
Im not very well informed on how to fine tune, I had pcmofnc do that for me. They did the basic + 3 fine tunes based on datalogs Ive sent em. Ive sone some reading and learned that Id have to keep looking at my KR tables and copy them to somewhere and re-tune. Is thay what you've been doing for re-tunes?Exactly. In fact no my tune would not be good digglesworth's truck at all. I have a 3.7L and have the air in take adjusted for two things different than what you have. Much higher altitude and I have a Jet maf sensor. My regular cruising altitude varies from 4200 ft to 5000 ft then when I hit the trails here I'm above 6k easy. Much thinner air than IL. Which means I need more of it to reach the same O2 level as the Cali guys. Fine tuning that balance comes from data logging. Then you: Tune-check. Tune-check. Until you are right on the money.
Again don't get me wrong mail order tunes can get you close but to get the most power and hopefully more fuel eco you have to do data logs and adjust your tune for your vehicle and for the way you drive.
But yes you can save your config files. In fact I have close to 30 different tunes saved. Every time I change something or a few parameters I save a new file so I can go back if I need to. All the way back to stock. Also yes you can go off the parameters and mimic someone else's file but the actual config files are specific to my VIN. So they wouldn't even download to your PCM. We would have to make a file specific to your truck then adjust the parameters from there.
Kind of. So yes you want to keep an eye on you KR tables. (Knock Retard for those reading and don't know what the hell we are talking aboutIm not very well informed on how to fine tune, I had pcmofnc do that for me. They did the basic + 3 fine tunes based on datalogs Ive sent em. Ive sone some reading and learned that Id have to keep looking at my KR tables and copy them to somewhere and re-tune. Is thay what you've been doing for re-tunes?
Great info Arborne! I was looking at the Banish books but there a ton of them, which is the one you would recommend? This is something I would like to get into some day.
"Ex Umbris Venimus"
