Enter Hummer
- Southwest
So a couple of weeks ago my transmission cooler line poped out of the radiator and lost some transmission fluid . I topped it off and drove it around a little bit and kept topping it off 'til it was full and wasnt taking any more. About a week later I checked the dipstick cold (it does have a cold line) and it said I was WAY full. So I took it for a drive and pulled over and checked it warm with the engine running and the fluid was at the VERY bottom of the dipstick (under cold). I have checked it a few times, hot and cold, and I keep getting the same results, full on cold, low on hot. I've put probably a couple hundred miles on it since then and it drives fine now. I dont know, Ill keep an eye on it and see what happens.
I want to know if any of you have had a similar problem or any ideas to whats causing this. Any help/ideas is greatly apreciated, thanks in advance
BTW, this is the 3.7L i5 4speed.
