pcf
Mayhem:
Not sure on the significance of the back 1/2 of the Scorpworks one sticking down a bit? They don't strike me as the type to do something like that without a reason, I'm assuming it catches the lip below the clamping surface to increase grab? Both appear to be a very solid clamp setup, I'd want the bushings for the other side as well, as IMO, clamping one side WILL create eventual failure on the other side.
Don't think you'll go wrong either way, it's not a complex piece... it just needs to ACTUALLY clamp the rack on the pass side, and once the force is stopped from going that way, you need to keep it from being able to spread the other way.
Not sure what the mayhem guys used for the bushings, but my fab guy who makes bushings for high pressure, high impact situations made me some from ABS and they degraded very quickly. I feel delrin would be a good material to use, but we discussed that in the obnoxiously long thread at one point & I can't remember what the greater minds than myself said about it's fitness for this situation.
