PANIC ! H3 wont start !
lsv_palana
Kamchatka, Russia
My hummer h3 not start... starter working fine.. engine not start.. looks like there is no fuel... how i can check is fuel flow from tank to engine...v8 5.3l ... please help !
Отправлено с моего SM-N910C через Tapatalk
Listen for the pump when you turn the key on. If no pump...check the f.p. relay. You can bypass the relay with a paper clip, to get home.
Also...kick the bottom of the tank with your foot...this can sometimes shock the pump into running.
I think the relay would be in the fuse box (under the hood). Yes...pump is in the tank.
lsv_palana
Kamchatka, Russia
Starter works fine... it crank engine.. if passlock failed engine not crank ? Is it right ?
It won't turn over if passlock is the problem. It will click but that's it. It's either a fuel or spark problem if it's turning over but not starting.
Sent from my Nexus 7 using Tapatalk
lsv_palana
Kamchatka, Russia
As you know i have tech2. Tech2 does not show any errors.. so i think if it is passlock issue then tech2 must show some errors in theft module ? If no errors this mean that some mechanics error that tech2 cant see...
There is a grey wire that comes off the fuel pump control module, with this key turned on check for power coming to the Fuel Pump Control Module (red wire) and power coming out (grey wire)
If no power to the grey wire you can run a switched wire and tap into the grey wire to get you home/to a mechanic
Bruces
Portland, TN
My pass lock has prevented mine from starting three times in two years. Each time it turns over but does not start. Go through relearn and it is good for another six months.
is your padlock on dash flashing or solid?
lsv_palana
Kamchatka, Russia
I have removed fuel pump from tank. I connect fuel pump motor to battery. If works fine. Fuel folow from it fine. Does anybody have fuel pump harness diagram ? Wich wire ABCD going to motor and wich going to fuel level indicator ? I have cleaned ground wire that located near license plate near rear bumper. It ok.. i have checked fuse number 3 and relay 66.. seems to be ok... please help
. I can not start my car....
lsv_palana
Kamchatka, Russia
Here is my fuel pump harness
Happy Hummer
Wisconsin
Weird. By now you should've track down some sort of gremlin.
Is it possible that your not getting spark? Did you do a test visually to prove spark?
Is your crank shaft, cam shaft position sensor possibly boogers?
Air
Gas
Ignition
lsv_palana
Kamchatka, Russia
More problems come.. now i have traction control error, abs error. Passlock light on. I can not move gear selector on car and cant move car... and all this time car was on one place not moved even 1 meter... i have checked power on fuel pump harness while starter cranking .. it is ok 11 volts.. but fuel pump dont work.. i connect a bulb to this connector to A and D contacts.. no light... now my starter doesnt work.. passlock appear on panel.. WTF ? What going on ? I did not move car all day.. maybe battery going dead, but it works fine with winch installed on my car... maybe i have no ground contact somewhere ?
Bruces
Portland, TN
While engine cranking by starter padlock and all light solid
before you disassemble the whole truck try the easy things first. Make sure battery is charged and good battery connections. Here's the security relearn instructions.
Step 1 – Attempt to start the vehicle. It will crank, but not run. The security light will be flashing on and off. Leave the key in the ‘run’ position for exactly 10 minutes, then the security light will stay solid or go off.
Step 2 – Turn the key to the ‘off’ position for 10 seconds. Attempt to start the vehicle. Some vehicles will run at this point, although many will require you repeat repeat Step 1 two more times. Make sure turn the key to the ‘off’ position for 10 seconds before each 10 minute cycle.
Step 3 – The vehicle is now ready to relearn the proper code. Turn the key ‘off’ for 10 seconds and then ‘crank’ the vehicle. It should be running now. The security light might stay on solid for several minutes afterwards, depending on your system.
Traxx
PNW
When you start having all kinds of oddball errors it's usually bcm related. I keep a spare in the back just for stuff like this.
Yeah...multiple lights going on & off points to a voltage/ground issue. The H3 is HYPER-SENSATIVE to electrical problems.
If you have messed with your fuse box....double & triple check it for bad connections (on the bottom side). This seems to be a common place for resistance.
