I went into a puddle today, didnt look that deep and got a little stuck. Took about ten minutes to get out. Water started seeping in the door and got about up to the seat. From the angle of the truck the pcm looked completely dry, no water in the airbox or engine and was running fine. I had some error codes popping up while i was waiting to get out almost every error came on. Once i got it out i turned it off, then when i tried to start it up it wouldn't come on. Then i tried again and it came back on and ran normal. But then i drove it around and out of the way and turned it back off to clean out the inside a bit. But then now when i turn it back on it wont start. I get a bunch of random lights flashing, horn was blowing, and i cant get the shifter to shift through the gears the windows and locks dont work either. I have had the theft lock come on but it comes and goes occasionally, also the key wont come out most of the time. The fuel pump works like its supposed to. I blow dried the connectors out on the passenger side under the dash but i am lost on what else to do, any ideas? Getting it towed back to the house tomorrow.
