nickwood166
- Corinth Ms
Who makes aftermarket spindles for the H3?
You could possibly adapt some other lift kit on the market or spindles but that would take some mad fabrication skills.
Could always go with some portal aftermarket units... ha ha ha
Actually have a fabricator that owes me some favors for saving him a couple of deductibles. HaThey could be fabbed if you had some Rancho knuckles to copy. Basically mimic all the dimensions of the casting...except it would be milled, drilled, and welded. I’ve seen some fabbed knuckles on 2wd trophy trucks.
Of course they would be super expensive, and probably not cost effective to produce. But you could do one set for yourself.
Actually my front drive shaft has been out for a while because of that awesome velocity joint. LolAre you planning on keeping 4WD? The CV shafts are already maxed out with 2" lift! With a rancho the diff was dropped to fix that (at the expense of the front drive shaft thou)
But if you could find a rancho lift spindle online (they used to sell the full kit in seperate parts but at higher prices) then you got what you want.
