ADOR
- Las Vegas, NV
I have a 2005 H2, with 36,700 miles. It's lifted with Rancho Lift it, and 38 in tires. I has Rancho RS9000XL Shocks. The gears has been changed to 4.88 ratio. I also have the Superchips Flashpaq programmer. I can probably re-program the H2's computer once I tow.
I will be towing a 4,000 lbs camping trailer DRY. With propane, batteries and other gears that we will be carrying, it may go up to around 4,300 - 4,400 lbs. I will be using a Blue Ox WDH with sway control. I also have a Prodigy P3 brake controls.
I am not concerned about gas mileage, as I know it wil signifficantly go down. I am a bit concerned about the lift kit, 4.88 gears & transmission.
1. Is the H2 going to be OK with all of the stuffs mentioned above?
2. Can or should I still used the Tow Haul button in the dash?
3. Should I re-program the computer with the Flashpack for towing, or is the Tow Haul button enough?
Help and suggestions from those who have towed with lifted and oversized tires will be greatly appreciated.
