What problems do you see with 35" tires?
I haven't seen anyone mention the obvious yet. The stock front diff can break on 33's. 35's will only compound the issue. That said, I have 35's so it's all a risk/benefit, but it will definitely put more stress on your drivetrain.
I'm running 37"s and 5.13s now. However, my next H3 build will be based on 35"s and 4.88s. I love the 37"s but they're a tad un-practical for daily driving. Even though I have no issues with them...the truck feels like a monster driving around, and it barely fits in my garage. I also think that I can go anywhere on 35"s, with the same effort as I do on 37"s (giving up only an inch of GC). On an stock IFS rig, you might notice more performance changes in tire size. But with the solid axle...it doesn't seem to matter much if you have 35"s or 37". With a 4:1 crawl ratio, 5.13s, locked f & r, and 37"s...offroading is whole new experience. Its sometimes difficult to keep the corners of my mouth from meeting at the back of my head! Its hard to compare this to wheeling a stock H3 but, I remember the multiple stages I went thru to get where I'm at now (t-bar crank/Rancho/SAS).
I think the gearing issue is far more important than tire size, and that's what sucks about the stock front axle. There's simply nothing you can do to make-up for the ratio change that large tires cause. Not to mention...the stock front axle is barely adequate for 265 tires, let alone the extra strain 35"s put on it. I've wheeled with many stock H3s and they can go 90% of the places I can. Hell...you should have seen Schwartzy on the rock ledge at the Badlands last year, and he was on TOTALLY BALD stock Duellers! If he would've had better tread (the same size)...he would've made it!..
My point is, that good aggressive tread can do wonders, even if you keep a relatively small tire size. On any other 4x4, I would probably disagree...because you can always re-gear to compensate for larger tires. But not so on the the H3. Its so under-powered, and the front axle is so weak, that to me...it makes more sense to keep the small end of tire size (285s to 315s). This keeps the motor & tranny in its intended power-band, and also helps you stay within the ridiculously low stress limits of the AAM-7. Given the choice...I'de take a smaller tire with great tread design over the ground clearance and gearing issues of a larger tire. 35"s are great off-road but, they make your 5-cylinder completely nut-less on the highway.
I'm sure 35"s will be about as much as the 3.5 can handle. After the ECM tune, there is not much else to do to get reliable HP from it. Besides, the lower HP will keep me from breaking more stuff, lol.
I recommend something smaller than 35s for a 3.5L. I did that on mine and Im a constant daily driver, I do offroad a couple of times a year but that doesn't justify the power loss. Offcourse they look great, and I believe the truck look unbelievable with 37s, which is why I got an Alpha (got 35s installed on it). If you can get an aggressive 33" or a 34" I'd recommend it for the 3.5L
As for backspacing, Ive got 315/70/17s on 4.88" backspaced wheels, 17x8, and they completely eliminated rubbing on the sway bar. I haven't levelled yet so I get rubbing on the mudflaps (have SA model that has larger fender flares/mudflaps installed). Other wise everything runs great. I checked that setup on my levelled 06 which doesnt have any flares/flaps and didnt get any rubbing at all.
Michro
DFW, TX
I think the 295 trail grapplers are pretty perfect for the H3. Funny enough, there's a blacked out FJ Cruiser at my apt which convinced me that the trail grapplers both look great and have good tread design. And the size isn't too large to affect the performance too badly, especially with a tune. I'll be getting these tires as soon as 1K doesn't seem like a huge expense.
chaos254
This is a good thread, I've been debating between 305/70r16 and the 35s. I'm not worried about the gas mileage but the additional wear and possible breakage of parts is what has me going back and forth.
Sent from my ADR6425LVW using Tapatalk 2
poncho1965
Ridgecrest, California
I've also been tossing this around. I don't 4 wheel enough to justify 35's. My H3 is a pig with the I5 as it is. In the end I believe I will end up with 35's if nothing else, just to experience the cool factor for myself :)
Mike
SkinGripz
Horse Country, Texas
Mike
Mike- You drive a Hummer, you already experience the "Cool Factor" ! It's a burden, I know, but it's not like the Jeep guys are gonna step up to bat.... ;)
"If at first you dont succeed, come back with a big damn stick". -My Dad
