What problems do you see with 35" tires?
I will be buying new tires soon and I would like to go up to 35", 315-75-16, from the 33". I would like to know how much rubbing or other issues I should expect. T bars are cranked to 23.5" and I have Ultra Wheels Badlands rims with 4 7/8" backspacing. BFG AT will be tire of choice.
Thanks.
cdarveaux
Colorado Springs, CO
You should be fine I T-Bar'd (not sure of the measurements) but I put KM2's on and no rubbing whatsoever even though the dealer said they would I loved to look an their faces when it fit perfectly! Other issues, MPGs will be reduced due to the larger size but they are really worth it off road.
jakesz28
Cabool MO
With the increased back spacing those rims have you can expect more tire rubbing then the guys running stock wheels.
arkalpha
arkansas
I leveled mine as soon as I got it. I had factory wheels with 285s. Then I put 17" wheels with 4.5" B/S with 35x12.5x17 M/T's on and they never rubbed. Mine is an Alpha, but I wouldn't think that would make a difference on daily driving or turning lock to lock.
TAPADROID
Biggest problem?....Gearing.
You can pull your ECM/TCM and send it out to get re-flashed. This will adjust the shift points, correct the speedo, and generally make the bigger tires less of a power sucker. PCM4less (now called something else) did mine...works pretty good but, it can only do so much.
I have the adventure package so I am geared the best I can be from the factory. I am ready to pull the trigger on the ECM mode from PCM of NC. I have talked to them several times, just waiting on instructions to remove it.
Has anyone had transmission issues going to larger tires? I know it puts more of a load on it, my trany guy says the stock cooler is more than enough unless I do hard core crawling.
your geared the same w/ or w/o the adv package in terms of differentials (which is what matter for street) the 4lo is the gearing that helps offroad.
SkinGripz
Horse Country, Texas
The only problem with putting 35's on is the next day, you'll see someone with 37's....
Have 35" Kumho's on the H3 and debating on either 35's or 37's on the new H3T Alpha.
35's look great, 37's look bad ass (but suck the life force out like an ex wife)
"If at first you dont succeed, come back with a big damn stick". -My Dad
R
R-code17815
Nail on the Head!!!!
I put on Kevlar MTR's in 315 (35"), should have stuffed 37"
It never ends!!
I'm sure 35"s will be about as much as the 3.5 can handle. After the ECM tune, there is not much else to do to get reliable HP from it. Besides, the lower HP will keep me from breaking more stuff, lol.
chad
florida
anybody on here run 34" tires? what is a big difference between 34&35 tires? cant decide which to get, any thoughts?
Kyle
Santa Clarita, CA
The only problem i see running 35's is the amount of money left in my bank acct after i go to the gas station and fill up, every week and a half!
3rdH3
Blacksburg, VA
I have seen 34's 295/75/16 General Grabber AT2's on an H3 and they looked good. They were on an 06 Base and I didn't hear any complaints about loss of power.
The only downside is there is not a large selection in the 295's.
08H3I5
Oklahoma
This is the debate I am having right now too.... Just got my 08 H3 Base and it came with a brand new set of 265s on it. problem is that that are mild ATs more geared to the pavement and I hunt and get in some deep sand and muck sometimes. I was considering a set of 285s that are aggressive but the 315s are tempting me like CRAZY....decisions like this suck!
08H3I5
Oklahoma
biggest problem I have right now is trying to justify where the $1200+ is going when it comes out of the bank......
chaos254
I've been debating on 35s for awhile now. Seems like most complaints about mpg/power loss come from people without a tune.
Sent from my skz_tenderloin using Tapatalk 2
M22KLARS
Unsafe At Any Speed
Minnesota
The only problem I ever had was all the country girls trying to hop in for a ride. The wife wasn't pleased. :)
H3DONIST
USA
Some of us without a tune, just accept it and don't complain, because the good outweighs the bad...at least in my opinion. :thumbs:
chad
florida
i was wandering about the 34's, never really hear anybody run them, since its only an inch from 35's would it make much difference on power and gas or not be noticable? i dont have a tune yet either.
