Moab Black Sheep Week -October 7-12, 2012
H3TBone
El Paso, TX
Chris also talks loudly in his sleep. About guys.
Raptor armor will be here Tuesday. This 145" wheel base will need all the help it can get.
That is believable. If I fall asleep on the couch someone will wake me up asking what I was trying to say.
H3TBone
El Paso, TX
I trust it is lined with HDPE so you just slide over everything. :)
I have 16" of clearance with 37's and a small lift, so it's not as bad as it sounds. My skids are steel but aluminum for the gas tank. I will apply my HDPE plans for the Hummer to the gas tank first (it is loooong, 36 gallons). If I'm successful, I will plan to use it on the other skids and the frame rails.
It can be purchased in sheets or strips from McMaster-Carr. mcmaster.com. Comes in black though it is typically white.
abearden
N. Idaho
Just gave the boss heads up about taking the week off and got the "we will need to talk about that" response because his anniversary is in the same time frame. Hmmm...
Cook, there is no cost for the trail trips except the passes required for some trails. ($5.00/day) Whatever you spend in gas, lodging and food is the cost of the trip. We welcome everyone and look forward to meeting you.
Cook, you're of course welcome to caravan with us. We'll be heading up on Saturday the 6th, leaving Phx around 8-9 am.
