HELP!
Ok, so I just measured the distances from the center of my wheel to the fender lip: Front: 23.5-24" Rear: 24.5-25"
The tech who installed the lift said I only gained about an inch or so of height in the rear...I looks like more than that to me, but I'm trying to figure it out. He also said they didn't bring the front up as high as it could go because the rear was not raised too high.
I parked next to a stock H3 last night for the first time and did not look as noticeably larger as I thought I would...
Couple of questions for you all:
Can anyone give me the distances from the center of the wheel to the fender lip for stock ride height?
-- Seems OEM height is 22.5" front and 24"ish rear.
Also, to bring my front level with my rear height, would that just require a t-bar adjustment, or is there more to that?
-- 06 H3 has informed me that this is correct. It would just be a simply t-bar crank now to get the front up to around 26" where it should be. I'll need to use a 1 1/16" socket.
EDIT TO UPDATE: I took the truck back to my mechanic to adjust. He couldn't bring the front up too much before because the rear add-a-leaves were not lifting much. Once I added extended shackles in the rear I was able to have the front brought way up and give the truck the height it was supposed to have.
