- Bellflower, CA
Has anyone removed or replaced the 4 side window rubber seals? Going to be spraying Raptor liner next week and those are the only items left to pull.
Yeah, that ain't going to happen. Sounds like I'll just tape the rubber.You have to remove the door regulator panel (inside) and remove the glass. I believe there's a bolt inside to move the track/s so you can rotate the glass to get it out. Lot of work for 4 doors, but you're close...
It's great. It does sway a little because I don't have a front sway bar. Other than that nothing ugly at all. It is a dedicated trail rig so it only sees highway miles to/from the trail.How does it drive with the SAS? What's the good/bad & ugly on the conversion?
