Will this fit?
One of my future mods it to get a winch system that keeps the OEM look. That being said, ill either be getting the DOI or predator winch mount.
I do want a more powerful winch in there, along the lines of 12,000lbs. I found this warn winch: VR12000 that looks like it will fit if you remove the soleniod square box looking thing
http://www.warn.com/truck/winches/VR12000_winch.shtml
For those of you who have the DOI or predator winch mounts, will it fit? Thanks
Here is the measurement diagram.
Thanks again.
Seems like by doing a little more research has answered my question. Yes it will fit, I compared the diagrams of this winch to other winches that have been said to fit.
SolidusJ
FT. Carson, CO
Thanks again.
Look like the DOI mount bolt pattern is 10.0 X 4.5 inch which is the same as the winch, I believe it should work.
Not sure a 12K winch will fit the DOI bumper...very tight under there. 08H3 has one...maybe he can chime-in.
BTW...9.5K seems to be plenty of winch for the H3. If you get into a real jamb you can always use a snatch block to double your pull. Considering the space limitations you have vs. winch capacity, its not such a compromise to go with the smaller one. Its less weight, less money, and fits without mods. I doubt if the larger winch would be worth the extra effort (unless you already had a 12k you plan to use).
Another tip: Use a 50-foot winch line, and a separate extension line. This will keep the layers on your drum to one or two...thus closer to the rated capacity of your winch. Every layer of winch line...de-rates your pulling power, and I've noticed that I do most of my winching in the 20ft. to 40ft. range. So I have the remaining 60ft. of line still on the drum, and I hardly ever use it. It does nothing but de-rate the power, and cost more weight and money...so I'm going to use a shorter line and carry a separate extension line next time. I think this depends on where you wheel but, I rarely need more than 30-feet here in the midwest.
Thanks for all the great info CJ.
The reason i was looking at a more powerful winch than a 9.5 is that i know im going to be doing some expeditions in the future and ill have a lot of weight on board. I just want to make sure that if im in a bind i can get my self out.
sinstr
south fla
I have the M8000 with a synthetic line in my DOI. Its a real tight fit, and you have to clock the end but thats easy on the M series. Make sure the end cap is removable so you can clock it. Im not sure on the VR model.
And if I can make a suggestion, get the wireless remote. First time I needed my winch, it was raining and I used it 5 times in one afternoon. Running the control from the grill to the cab just sucked!!
