What is the largest tire that will fit on H3 with no modifications
dbal44
Ma.
Looking to put Nitto Trail Grapplers on 20 inch rock star rims on a 2006 H3. Dose anyone know what the largest tire I could go with.
skippy
brisbane australia
if you are running no lift and want to run 35's you have to keep the off set as standard there will be some rubbing on the sway bar on full lock!
Chocflip201
In the Rocky Mountains
Utah
35's no mods / minimal sway bar rub at full lock.
35's no lift, but -6 offset wheels, no rubbing
35's Rancho lift - no rubbing
I thought -6 offset would rub like crazy with no lift... Mine is only +15 with 35s and it rubs
I was running +10 offset with 35s and never had any rubbing! Now that I've added a body lift, I'm swapping my wheels to as low as -12, hopefully I won't have any issues.
poweraidon
georgia
Then why am I rubbing? And damn I was gonna get negative or a lower offset than 15 but someone on the forum told me I would get a lot of rubbing but apparently not. I'm kinda piss
The part broken looks to me on the outside of your fenders, Am I right (I honestly can't tell from your picture)? If so its possible that you've stuffed your tires into your wheel wells while turning and at speed, if so the problem could've been caused by your bump stops! (Are you running extended ones or stock?)
My friend was running -2 offset on the rears with 35s + 1" body lift and he got the tires to touch the fenders while wheeling, turned out his bump stops were shot! Replaced them and never had to worry about it anymore!
Remember, poweraidon wasn't running ANY bumpstops for a while. Could've been during that time that he stuffed a fender.
