So after putting about $6k in mods into my 2007 H3X, my transmission crapped out yesterday. 1st and 2nd gear still work fine, but the rig won't shift into 3rd gear and my maximum speed is about 55mph. When it first happened, the check engine light came on with a P0756 code:
P0756 Shift Solenoid 'B' Performance or Stuck Off
Assuming the first or second causes, I brought the H3 in for a transmission fluid change, but it still wouldn't shift into 3rd after the fluid swap.
I then brought it into my local GM dealer and they are recommending a FULL transmission replacement at $5,000!!!! Their tech says my H3 was hooked up to their scanning tool and it can't locate 3rd gear, so they think internal parts are worn. They also said they found error code P0218 (transmission over temp), but I never saw that code on my tool.
I'd probably sell off the H3 and get into a new car for $5k, so before doing that, does anyone have any recommendations on this?
1. Could this all be caused by a faulty Shift Solenoid B (the original error code) and it just needs to be replaced?
2. Do any of those no slip additives work? Should I try topping off my fluids with those? Any recommendations?
3. Accepting donations if nothing else works and I have to replace the tranny... :gaah:
- Low transmission fluid level
- Dirty transmission fluid
- Faulty shift solenoid 'B' valve
- Shift solenoid 'B' valve harness or connectors
- Shift solenoid 'B' valve circuit is open or shorted
