Reloader
- Montana a free state
I'm on my second steering shaft. It's the shaft with the little u-joints between the steering rack and the column under the hood . Mine was replaced under warranty but i think I'll need a new one again in the future. You get a clunk/knock in the wheel whilst a turning. Only proper fix is a new shaft assembly. This happens on a lot of GM vehicles. We replace a lot of them at times . The aftermarket has started to make them for several applications. Toyota's even have the problem in some models, but Toyota has us try to lube them first. New shaft is still the best way to go.
Anyways, I was wondering how many of you have had yours replaced . The actual part doesn't cost that much. Should be about a C-note for the part. I don't think they are available for our H3s aftermarket. Sorry , no picture of the shaft but mine is rusty and looks bad.
What say you.
What say you.
