Scorpworks Steering Rack Bracket -six months in and still going strong!
I've had Preferred Chassis Fabrication's Scorpworks Steering Rack Bracket on my H3 for six months now. And it's still an awesome upgrade.
The steering in my H3 has been an on and off drama. Anyone remember the intermediate steering shaft issues back in 06 and 07? Took a few trips to the dealer and a couple of replacement parts to get that fixed.
Then, because I was a bit foolhardy (clueless?) I had my torsion bars cranked to 24". Lots of wheeling and at 40,000 or so miles I had to replace my steering rack. The inner tie rods wore out at the rack. I tried replacing only the tie rods but that as merely a bandaid, and I still ended up doing the rack later.
I replaced the OEM bushing a couple of times after that. I tried another fix but because my frame's rack mounting plate was likely out of alignment (20/20 hindsight) that fix didn't work for me.
Essentially, most of the time that I've owned my truck - six years, 120,000 miles before I did this fix, I had a truck that had loose steering; steering that was clunky and steering that just didn't feel right.
So, February 16, 2013 we put the PCF Steering Rack Bracket on my H3. Dwaine did most of the work as I had a bruised rotator cuff and couldn't do much with my shoulder. I took the pictures.
On that first test drive, I couldn't stop smiling. The biggest telltale of the awesome improvement was going over railroad tracks that intersected the street at a bias. Previously, the steering would induce a shiver through the vehicle as the tire would move the rack which in turn affected the other front tire. Hitting two rails at two different times was essentially jogging the rack up and down, back and forth, at a rapid pace. The loose steering, clunkiness and vagueness all disappeared.
This design does not overclamp or bind the thin sheet metal of the rack, which may result in the steering not wanting to return to center.
My next test was Moab, in particular on the crack on Seven Mile Rim. I accidentally entered it lazily and the rocks grabbed the wheels hard, jerking them to the left in the crevice. The smart thing would be to back up, straighten out, and re-enter the crack while firmly holding the wheel to prevent that from happening again. The fun choice was to put the Scorpworks bracket to the test. While in the crack, I firmly grabbed the steering wheel and forced it back to the right. I figured the possible outcomes were: 1) Success; 2) Failure of a tie rod; 3) Failure of the bracket. I ended up with Success.
Here's a picture of it in Moab when I did an inspection for any issues (none, of course). Frankly, I'm much less worried about carrying a spare rack on the trail now that separation of the rack (the primary failure) is much less likely because this bracket holds the rack in place, preventing separation. I've also seen failure from the PS lines breaking at the rack due to the rack movement, and that's not likely to happen with the PCF mount. I'd rather spend the money on this aluminum bracket than a PS rack - less money, and I don't have to carry that massive (and heavy) spare with me everywhere.
For those doing the math, this rack has about 89,000 miles on it now with no wear and tear issues on the remaining bushings, the tie rods or the steering action. And if you check out my SmugMug pages, you can see that it's done a few trails. alrock.smugmug.com
2010H3TAlpha
Issaquah, WA
This is reassuring for me, mine arrived a couple weeks ago and planning to have it installed next week. Only 18k on my rig now so hopefully I've caught it before too much damage has been done.
cbetts
NERD!!!
Rancho Palos Verdes, CA
Unfortunately, I have not done many trips in my truck since the PCF mount was put in mine. However, I have noticed improvement on pavement. I was quite used the having a little steering-bump when cruising down the highway. Once the PCF mount was installed, the H3 steers straight as an arrow and virtually all steering bump removed.
Reloader
Montana a free state
I too have installed a Scorpworks steering bracket on my H3. It's been about 3 months and everything Alrock says about it is true. After installing it my steering wheel was off center but that was expected as the bracket that I had reinforced prior to Moab this spring was bent up. installing the Scorpworks bracket put the rack back into the proper position so a toe set was needed.
The only problem I seem to be having is keeping the left side mounting bolts tight. When I installed the bracket I put new GM bolts and nuts in the left side and torqued them to GM specs with locktite. They still loosened and you can tell due to a clicking in front end when turning slightly. The last time I used torque specs from my days long ago in heavy construction working on caterpillar and other brands. Tight as you can get it and a half a turn more with a longer extension. We will see if this keeps them tight.
I carry spare nuts and a jumper line assembly made from the lines off my old rack that I destroyed on a little obstacle in Moab called Hells gate this spring. If somehow the rack were to separate again and flex and split the pressure lines again, I can just install the jumper, refill pump reservoir so pump doesn't burn up and continue on using old fashioned strong arm power steering. But the design of the Scorpworks bracket should prevent any side to side movement due to how it mounts snugly against the right inlet fitting on the power end of the rack.
One other thing I carry is a piece of 10mm Allen wrench about .5" long which allows me to check the Allen head bracket bolts supplied with the kit using a 10 mm box end wrench. This way you don't have to loosen the diff mounts to get clearance to get an Allen socket in place gods forbid you were to need to change out the rack.
that is all.
Reloader has a brand new rack as the old one came apart in Moab, pre-Scorpworks mod. It was the driver's side bolts that backed out on him
Nacho
Now with Chese
Installed the the Scorpionworks bracket and Diff bushing last weekend can already tell a difference, glad to hear they are holding up to the abuse. Just need to abuse mine now.
The bracket had another good test last week in Moab. Actually, it got tested a bunch with these three trucks all sporting PCF Steering Rack Brackets and Crossmembers. Reloader and I were both commenting after the trip on how an alignment is often needed after the Moab trip with things getting knocked out of place, but none was needed after this trip.
Jerry replaced his tired rack and upgraded the OEM bracket to PCF before this trip and noticed how his truck went from driving like the Exxon Valdez (but no seals harmed!) to tight and accurate steering, better than new
Danster
How/where can I order the Scorpworks Steering Rack Bracket? Also want to have the crossmember done as well.
TIA!
Dannyo
Send a private message to Preferred Chassis Fabrication here on the forum to place your order
Sent from my SM-N900V using Tapatalk
mantracker
Tennessee
I too, have installed PCF steering rack bracket and diff. cross member bushing, quite a while back. I've been offroad a few times on some moderate trails and quite a few highway miles. Absolutely no issues. This was two of the best upgrades I've done, so far.
mantracker
Tennessee
Have no fear. Just get in there and do it. Dwaine supplies good instructions. Read over it several times and look under your H3 and get familiar with it. It's not that hard, and you can call Dwaine if you have a question.
Is the pcf bracket the only one that can be installed without removing the rack? I assume that's because it is the passenger clamp only. The other kits have new driver side bushings that have to be pressed out... I still haven't figured out why the pcf bracket has the o rings to keep it from being a fully rigid setup. Is it for dampening purposes? And may be a little off topic but anyone have any info on the jumper that can be made to bypass the rack and keep the pump alive in the event the rack breaks?
954paulo
ny
I got a chance to get mine installed yesterday. What a pain in the ass it was to install. But got it in and drove it around for a bit, I didn't notice anything major accept more of a slight vibration in the steering wheel. Drove over a few bumps in the road and no more bump steering, Nice improvement.
cbetts
NERD!!!
Well, found another item to add to my pre-trip checklist. My steering has had a thumping noise the last few weeks. While I had the truck apart to upgrade my air system, I discovered the bolts for the PCF steering bracket came loose. Not the easiest thing to get an allen wrench on but my Alligator pliers gripped the lower bolt just fine. I was not ready to drop the diff. Oh well . . . back to snug now.
PreferredChassisFab
Yosemite Sam
Tucson, AZ
The ScorpWorks bracket is designed to strengthen the weak/light right side rack frame mount. Most right side rack frame mounts are distorted when disassembled and close attention/inspection is needed to get the best surface contact between the frame mount and bracket mounting surface. This is explained in the installation guideline sheets provided in the bracket kit. The correct bolt torque will cause the frame bracket to form to the bracket. Too light torque will not force the frame mount to form to the bracket mounting surface thus allowing the bolts to work loose. It is recommended bolts be rechecked after the test drive and during chassis inspection.
A 10mm hex bit and long 10mm box end wrench allows for access to tighten the bolts .
Reminder: A bolt not properly tightened will not stay tight and can not be expected to do so.
cbetts
NERD!!!
Not disagreeing by any means. Just posting my experience so others can learn from my misfortune. Going to run a trail in three weeks to see how she holds up. I wish the lower bolt was easier to get access. I only have about 3/4" to squeeze the hex bit in there. I need to find a donor Allen wrench to cut a custom bit to carry. Until then the Alligator pliers will do.
Sent from my DROID4 using Tapatalk
2010H3TAlpha
Issaquah, WA
I would get the vibration checked out. Could be a bad alignment washer or loose bolt, etc.
It's also likely that your last alignment was performed with the rack itself out of alignment. Now that your rack is in place you may need an alignment
