Rear bags
rsc
Tulsa
No, for that you should look into extended bumpstops up front. A leveled H3 will put the oem bumpstops about 1/4-3/8" off the lower arm and that gap is what causes the extra dive under breaking. There are 2 sizes of longer bumpstops iirc, the shorter of the two is fine. The longer one tends to pop out offroad.
954paulo
ny
thanks but iv had the longer bump stops and leveled front for over 2 years.
rsc
Tulsa
You may want to try the Alpha torsion bars, its a higher rate for the additional weight of the Alpha up front. The stock springs are marginally sprung for a stock I5, with a winch up front and UCP the vehicle weight is too much for good control imo.
I am really loving my ride with the Alpha t bars.
