I bought a 2006 H3 last week. I have a couple of problems, but the most irritating at this point (followed closely by non-working key fobs) is the passenger rear door will not open. I can hear the actuator moving in the door when the lock/unlock is pressed. Nothing happens when you pull the handles, inside or outside. I can see a little bit of the mechanism between the door panel and the rear interior trim panel but not sure if I can get anything in there to push on the latch. Any ideas? Is it possible to get the door panel off with the door closed?
