NEW: Kryptonite COMPETITION Extremely HD centerlink and tie rods for H2!!!
tomp
Dallas
Finally, an even more heavy duty set of tie rod ends for our H2s! The ends are so large that the large pivot studs require you to pay a core charge until you return your factory spindles as they send you new ones with larger tapering in the holes! In order to run these tie rods, you must run both the Competition tie rods and Competition centerlink and their spindles:
http://dmaxstore.com/index.php?main_page=product_info&cPath=23_207&products_id=531
Do not confuse the above parts with the previosuly available Kryptonite centerlink and tie rods, as these tie rods have much larger pivot studs.
...and as soon as these Idler and Pitman arms are available, we'll have a super strong steering assembly: http://www.dieselplace.com/forum/showthread.php?t=461873
tomp
Dallas
In my opinion, the standard offerings seem a little narrow where they neck down at each joint, where the threads are. Increasing the diameter in this area seems like it might be needed.
tomp
Dallas
X2! So Tom, you gonna slap these on your truck? Looks like the perfect compliment to those RCV Half-Shafts! :giggle:
I will add this kit, if I decide to keep the H2. However, I'm really only interested in adding it, if those Idler/Pitman arms become available. With the stock centerlink and most HD tie rods, I'm convinced the weakest link is the Pitman/Idler arms, even when using the Cognito PISK.
[__--MUD--__]
South West Michigan
Got any pics of fabtech steering config?
Yea, bunch of tierod and steering linkage shots from about 5 years back after I put my lift on. Going off memory...think it was you I took these pics for as I was having issues aligning and guys were saying they needed to cut the tierods and some other bs. You gave me your number and I called you direct. Maybe? It was someone from texas real active on one of the other hummer forums ;)
http://s259.beta.photobucket.com/user/__--MUD--__/library/H2
