H3 Jeeperf Front Differential Bushings and Shocks
Steve #1
TEXAS
I've been away a while but I'm starting to get the H3 back where it needs to be. Rebuilding the motor wasn't cheep.
I need to replace the front differential bushings and came across these from Jeeperf. I'm curious if anyone has any experience with them or general input. https://www.jeeperf.com/product-pag...al-bushings-set-all-3?setCurrencyId=1////////
What's the latest opinion on replacement shocks? Not looking for anything fancy, just replacements.
Lauren
English in Dubai, UAE
I need to change my front diff bushing, I plan to order from Outfitter Design. Heard a lot of good things about them! https://www.outfitterdesign.com/do-it-yourself-front-differential-bushing-kit.html
For shocks, I replaced mine back in February with Fox IFP 2.0 and I love them!
I've also been recommended Bilstein shocks, again heard a lot of good things about them. However, I haven't tried them personally
For about 30 years I tended to buy Monroe (mostly) and sometimes Gabriel shocks and have installed quite a few on my vehicles. I was buying on price. They don't seem to last very long for DD use and usually 1 out a set will leak in less than 2 years. On a few I was able to get a replacement no charge, but on one expensive set I wasn't able to (that was NAPA's call and the guy was too lazy to look my order up). But why should I need to do that? Personally, I'd lean towards Bilstein's because overall they have a stellar quality rating. Anyway, I stopped buying Monroe or Gabriel shocks.
I bought a set of OEM GM shocks for my H3 (same part # as OEM) but haven't installed them. GM claims they spent quite a bit of time tuning the suspension on H3's, and there are multiple shock numbers depending on the suspension pkg your vehicle has, that's one reason I wanted to stick to a factory shock. The GM (AC Delco actually) replacements look exactly like the originals right down to the original markings, stampings and plastic boots. The ones I bought match the part number on my vehicle. To be honest, I haven't noticed any ride issues with my vehicle, but I wanted to buy Factory replacements in case GM discontinues them. At 160k I went to install them but after removing and hand-testing 1 rear and 1 front, I couldn't detect any looseness or shock travel issues so put the old ones back on. Maybe next year or the year after I'll replace. GM replacements cost a lot more than the Monroe's but I know they're tuned right and I've NEVER in 35 years had a pair of Monroe's last 50k miles w/o leaking.
Sooo, dollar for dollar, hard to beat Factory shocks for longevity. For comparison sakes, my wife's DD jeep has over 200k on original shocks (still rides nice) and my Tk has 150k on original shocks (rides perfect ..although 1 has started to leak). Land Rover used Bilstien shocks for years and a lot of owners would get 150k or more out of them. A member on the Land Rover forum once took his Bilstiens at high miles and put on a shock tester he had access to (with new bushings) and was surprised they were within specs. If Factory shocks weren't available for the H3 I probably would have went with Bilstiens.
You have the right idea to pay a little more up front for the Bilstiens. I can't comment on Fox shocks.
On Diff bushings, I recently installed an inexpensive $15 stock-looking China bushing I found on ebay. The quality looked as good as any Moogs or Delco I've installed over the years. I'll report how long it lasts. I just did the center. I considered the urethane kit ...I may install them if I have to remove the entire front diff, but I had to plug an emergency bushing so I went cheap on that one. I have a press so removal/install was a breeze, ..even if I have to do it again in 50k miles. If you wheel or drive hard-core, probably should bone up for the better bushings. They look well made.
A while? It's been forever! Glad to have you back.
For shocks, I like both OEM and Bilstein. Both have served me well and neither one is expensive.
Exodus
Alaska\Philippines
I had an Izusu rodeo that the shocks weren't so good so i replaced with monroe,Big mistake,the older shocks had a much better ride then the new monroes
Colorado
Jeeperf differential bushing
I ordered the jeeperf diff poly bushings I’ll let you know how they go when I get them in.
Alpha Tango
BC
I used Jeeperf bushings in my 07, and outfitter Design in both of the H3T. I'd say they were different, but equally as good. The Jeeperf have a metal shell like the OEM with polyurethane rubber. The OD is just Polyurethane rubber and no shell.
atvspeed4
massachusetts
We do not use polyurethane in our OD bushing kits for the front diff. Totally different material. UHMW with additives that make it UV stable. Ours will not break down over time like polyurethane. We have installed, uninstalled, and reinstalled one of our first few kits we prototyped in two H3s and several different front diffs since around 2014 and still working great.
fordee7
I'd prefer yours over Jeeperf and I've been holding off waiting for yours to get back in stock. I'm running out of time - can you give us an ETA on the front diff bushings yet?
Soleiltan2
Colorado
They are out of stock and have no idea of when they will be in. I also need replacement bushings!!!!
I'd rather wait till more of the OD bushings were in stock than pay double for something like that. Nearly $400 for 3 bushings? That's nuts. Most of the cost looks to be the fact they're machining the sleeves on a lathe instead of just having them formed from sheet.
If it's that dire of a need I'd rather just buy the stock bushings to use in the mean time.
