guruerror
- Gaithersburg, MD
I've got an intermittent annoyance where the interior 'courtesy' light on the passenger door panel under the armrest (LAMP. Auxiliary Interior Lighting PN15021518) will occasionally stay lit after the door closes and the vehicle is in motion. This is the only light that is affected by the problem, all other door panel lights function as they should.
It only occurs once in a while, but enough to be annoying. If I stop, reach over, and open and close the door it usually goes out.
I haven't even begun to look into it yet, but thought I'd post up here to see if anyone else has encountered the same problem.
Thanks in advance.
Thanks in advance.
