Thanks for reading my Post my Hummer H3 2007 3.7l I-5 with 88000 M on odometer runs like crap lately for last 4 days today i just bought a code scanner to find that it came up with 4 codes which are(P0171,P1133,P0133,P0128) starting by thermostat code P0128 was for stuck open thermostat (P0128 ECT below thermostat reg temp) any way i bought a new thermostat and the temp is back to 1/2 to nearly 3/4 and i erased the codes after a 10 mile trip same fuel in tank the MIL come back showing only 3 codes on scanner
P0171 engine too lean
P0133 O2 sensor circuit slow response B1 S 1
P1133 heated oxygen sensor HO2S insufficient switching B1 S1
here are the freeze frame records
DTC P0171
Fuel SYS1 cl
Fuel SYS2 N.A
Load PCT calculated load value 18,0%
ETC engine coolant temp 86 C or 187 F
Short term fuel 1,6%
Long term fuel 24,2 %
Map 29 KPA
RPM 601 RPM
VSS Vehicle speed 0
spark advance ignition timing advance 10
IAT intake air temp 57 C
MAF 3.00 g/s
TP 12.2 %
Air Stat off
please help me out i love this rig and i want to keep it till i find a good lo millage V8 alpha or plan on keeping mine till 200000M
FYI car use is just for off road
TB cleaned every 6 months -air filter changed with new one - EGR valve cleaned it was full carbon - filter is changed every oil change - used oil 10 w 30 AC Delco U.S.A -Coolant changed and radiator flushed at 80000m used DEX coolant - spark plugs changed with the same OEM model at 80000M - trany oil and filter changed every 30000M with dexron VI - MAF is cleaned with Carburetor Cleaner due to no MAF cleaner spray avilable here
Fuel type Super unleaded
now i see drop rpm at stops and accelaration is really crap fuel millage
what to tell 27L For every 100 KM no AC on
car temp is between 1/2 to 3/4 at high speed out city its even 1 mark below 1/2 and outside temp is 20 C
please help me thanks in advance what do i have to do to get it back to normal
DTC P0171
Fuel SYS1 cl
Fuel SYS2 N.A
Map 29 KPA
RPM 601 RPM
VSS Vehicle speed 0
MAF 3.00 g/s
TP 12.2 %
Air Stat off
