H3slate
Brush raked
- Tualatin, Oregon
I have a 06 H3 adventure w/ manual trans and 100k miles. I am having some noise and vibration at idle. The tach does not move, but there are noticeable shudders felt in the shifter and steering. I can also hear the change in the engine. It is not consistent, it is random and doesn't happen all the time. Under acceleration and at speed the truck feels fine. Only other symptom is when trying to accelerate at low rpms. Usually in 3rd, 4th, or 5th, if I am less than 2k rpms, the truck struggles to accelerate and feels like it is hesitating. Once above 2k it is fine, or if I down shift it accelerates fine. The check engine light has not come on during this. Even if I sit and let it idle for awhile with the odd vibrations it doesn't throw a code. I average 15 mpg with 35" tires and a roof rack. I have not seen any change in my mileage while this has happened. I have replaced the spark plugs recently with no change.
Any ideas on what the issue could be? As bad as this sounds, I keep waiting for it to throw a code so I can at least have a part or system to focus on. I am considering replacing the coils to see if that helps. I had previously replaced coil #2 to clear a p0302 code. The other coils are still the originals.
Any help with this would be appreciated.
