I'm pretty sure the H3, like every other modern vehicle, has post-cat O2 sensors. If you gut or delete the cat the PCM will throw an emissions code and light the MIL. A saavy tuner can delete the post-cat O2's to "fix" the problem. Personally, I like cats since non-catted gas engines stink. Even clean burning modern computer-controlled engines stink without cats. I dunno, maybe that's because I am used to the smell of diesel exhaust
The guys above who say the modern cats are very low restriction are correct - your muffler is a bigger choke point than your cat. IMO, if it ain't broke, leave it alone.
Finally, I should mention that when I still had a guzzle-ine engine in my Blazer I smacked the cat on a rock during a wheeling trip. It was a ceramic element unit (most common type), and it plugged and then started to come apart, and the engine ran like crap. Eventually, it blew chunks of the honeycomb core out over a period of several days. Truck ran great after that :wink: When I pulled the gasser to swap in a deezel, I removed the gas exhaust and in doing so got a look at the inside of the cat. It was COMPLETELY empty! Self-gutting cat!! :horns:
