G2 Light Bar Questions
F
Freddy
derian06
Red Rockett
Madison, AL
I have 2 amazon bars that work perfectly and weren't expensive at all. Mounts are great, can easily handle two bars. You can use riv nuts, or self tapping screws, I used self tapping screws.
razortray
I ordered the g2 brackets for $100
eBay 50" curved light bar $99
Oreilys switch $5
The 50" straight led bar I have mounted in these pictures I purchased from eBay also for $89. I also used self tapping screws. I searched every where my g2 brackets where all I could find. I believe there was a guy on the forum making them but you had to have them powered coated and drill your on holes in them not sure on what he charges I would assume much cheaper than $100
razortray
What did you use to add two light bars? Two curved bars would look great imo. I am also thinking about adding led pods on my intake covers just not sure how they are going to hold up.
H3HummerLineX
SoCal, Chatsworth
Moving to the 50" curved bar soon. Removing the rack and mounting the Hi Lift to the top roof rack rails. I'm thinking of mounting a pair of single row 12" lights on each side of the spare tire under the rear door as I have a 2" gap to fill.
razortray
The two 12" bars would look great IMO! How did you mount your pod lights? I order 4 all white 2x2 plan to double them up on each side similar to yours. Yours looks great btw. I think Iam also ready for a roof rack of some sort. I picked up a couple bags of mulch and two 5 gal jugs of gas by the 10 minute drive home my h3 smelt horrible. Would really like to be able to just throw that stuff on top.
A spot bar concentrates alot of light of a small side to side distance. Useful for long range (led scatters alot of light around so you get little lightig everywhere else).
My 40" light bar probably has a 15 meters across hot spot at roughly 300 meters away
scoreh3
H3hummerlinex how did you mount your little cube lights ? Did you just mount them to the fake air caps or did you make mounts ?
razortray
Started with a 50" straight installed a 50 curved today same specs the curved definitely covers more and looks better IMO
