FJ4overland
it wouldn't be the first time that a project I was doing encouraged them to take on one of their own - and it's totally the reason I post, if I can do it anyone can.... it takes awhile but it's worth it in my opinion
steering
opened up the hole a bit and got the engine harness into the cabin
it's waterproof so I think this is where I'm going to put the fuse panel....
misc stuff
the water pump is leaking, and there's a sound like the timing chain is rubbing on the timing cover.... both require draining the system...
onto adjusting valves
and buttoned back up
funny, I couldn't figure out why the motor was turning over so hard.... I suppose it being in gear would do that...
this, is an awesome purchase.... perfect flares every time
now you see it
now you don't
and I still don't think I have enough volume going to the slave cylinder... the FJ40 cylinder is ~5/8, this one is 7/8, the recommendation is 3/4.... problem is I have 1 1/4" travel available on the slave and only using about 1/2 of that (5/8").... which is a volume issue. but more playing with it is going to occur. I have several master cylinders, so next will be a 1" bore.... and we'll see.
onward
gas pedal
chop, reweld
now on the opposite side
and other stuff, blacking out the badging and the marker frames
the markers aren't quite done yet, I need dual filament bulbs because I eliminated the side signal off the grill
time to start fitting the center console...
New water pump, painted.
installed,
and picture for posterity of the belt routing
and found the source of my scraping sound
bent up and away from the balancer
yeah, stupid stuff
got the right(ish) hose for the hydroboost
and stole the heat cover off the wrong one...
and my tube bender needs a new bolt - weird, this $5.00 bender broke bending 3/8" steel line.... pos right?
first fit, maybe now some might see the reason I wrapped the headers.... smart, no?
with a little extra bending, it fit
and covered...
also the steering screws were drilled and installed with loctite and jam nuts
and ran fluid through the system
in other news, two extra holes after painting... dammit
also installed my new chrome valve covers
which replaced the very bent ones... and they're chrome, and cheap, and heavier gauge then GM covers... mock if you must, but be certain if you mock you best be someone who has finished more projects then I have... :grin:
time to modify the tank for efi
I really need to get my dies for my brake - I should be able to do 1/2" bends... but alas, no
edges trimmed
test 1
and drilled for the fittings
hopefully finished tomorrow
I know this sounds odd, but yes and no... I love building stuff, I hate being disappointed that it doesn't match the image in my head when it's done (which is why this is the 8th FJ40 I've owned)...
mostly finished with the pickup/tank
there it is.... whole system
once I got it in place, I had to bend the float over to clear... no biggie, it works
did I ever mention I never got the keys with this vehicle?
there it is, I still need to seal the access then pressure test the tank to be sure there's no holes...
I still don't know what I'm going to do about the holes but I do need to make inner fenders and this is step one
Today
run throttle cable
still need to find e-clip to hold it on....
clean up the sealing surface
and there it is with gasket... I still don't have the sealant, so I'll wait until I have that before making it tight then testing it for leaks
and I'll wait for another elbow to replace the one I just broke (dammit!)
fortunately, I could run one
lines run
nutserts inserted
hump installed
because I tied the bars together at the base, I had to move the vent
and moved
all lug nuts on.... I need to do an alignment, so that's kind of next
and get the front end installed... but here it is
starting here
spacer for air cleaner... I hate it and I'll make it out of something more durable then plastic
heater is sort-of in
yeah, I know, I was going to use the firewall... get over it, or don't.... I don't care
and now my clean rig looks like an explosion of wiring...
ah well, must make a mess to make it finished.
Sandblasted this
didn't have enough sand for the surround... ugh
finished up the air line
and spent time wiring... nope, you can't tell at all
though I did learn that europeans use white for ground... which would have been helpful to know. Fortunately, despite a complete lack of instructions online, some helpful Russian posted a youtube video where you could see how he connected the wires.... yay Russians.
we won't talk about how much time I spent with those lights.
random work
stripped the windshield frame and the front panel
halogen light bad without vent in the back
hmmmm, maybe move forward (note the use of special blue welder's tape? I bought that off Pirate)
and I put a cover over the wires, and will have to redo one wire ... ugh
back to the frames
about 1/4 of the way there.... I've done the easy stuff now I have to sand the corners and make sure that no stripper ended up inside the frame
and the other two bits
and started by etching the inside of the tank....
not pictured, I finished the fuel lines so once I line the tank the fuel system will be done.
a bit of unexpected time to dink on the '40
line the bottom
seal the pickup and return
connect lines
get sidetracked by honeydo
missed it by this much
oh well, either I'll move the seat over a bit or grind the offending plastic...
start button installed
and then I wired for awhile.... I hate wiring
Starting here
a ways to go here
looking better here
and now here
there will be a switch, though it might not be this one
and in answer to a question - this is a rough idea of what the sliders will look like
Narrowing in on vroom vroom
wiring the battery box (what a pain, I should have made it bigger)
if you look, you'll see there is power to the dash and the two gauges hooked up work.... not sure the oil pressure is right - but it works
and plumbed the heater core so I could refill the coolant.
I wired a switch to the ignition and the fuel pump makes noise - which says the computer is working since that is what turns it on...
tomorrow I'll pick up gas and see if it will actually make some noise
I've now driven it and..... oh boy, shocker, it drives quite nicely (don't tell Pirate, to them it's the stupidest build ever, dumbest build ever, will never get done build - we wouldn't want to blow their little minds).... I've not yet aligned it other then ball-park-tape-measure. But up to 40 mph it drives straight, doesn't bounce steer at all - which, to me, is pretty remarkable on bias-ply tires.
we now know it's equal to my wifes JoKe :)
no sway bar, yet, but again it drives pretty nicely
as you can see, some more assembly is required - but now it's no longer a static ornament and my worry about whether or not I got the geometry right is gone
and just to remind.... August 13, 2014, this is what it looked like
​brakes work well too, goes through all the gears.... it's almost like I know what I'm doing
Big2dabank
Central Florida
Great job and awesome workmanship. I hope your having more fun than frustration, I know my patience and sanity would not let me tackle something like this.
