Graham2990
- TN
So I've just recently picked up a beater car to use for my 65 mile round trip work commute to help save on gas vs. driving my H3.
For the first time since I've owned it (2 years) the H3 sat garaged for nine days without starting.
Yesterday when I attempted to start the truck the battery was dead enough that the keyless entry wouldn't function.
Battery is a 24 months old 34/78 Platinum Super Start (Oreilly Brand) AGM battery.
After getting it open and hitting a voltmeter to the battery it registered at 5.71 volts.
Jumped it off and let it run for 30 minutes, and then drove about thirty miles. Started right up the today with no issues, showing 12.4 volts.
My mutimeter is showing a parasitic battery drain / amp draw of 1.1 amps, with the key out of the ignition, doors closed, no lights on, ground unhooked, nada.
I haven't added any additional electronics other than changing to an aftermarket head unit (no amps, subs, etc) and a scan gauge.
Is this considered a too be expected amp draw for these trucks?
Went as far as removing the radio fuse and the draw was reduced by about .05 amps, so that isn't it either.
Thoughts?
Thoughts?
