Driver Side Window Switches
SchoonerDriver
Norman, Oklahoma
For some reason I don't know why but when the switches light up in my cabin at night like the window and lock switches, my driver side ones don't light up. Could there be a bulb out? If so is it possible for me to just pop a new bulb in? Thanks!
Best4x4
Vidor, TX
Yep it's either a bad bulb or dirty contact. Replacement bulbs are T4's with the base that will allow the PCB to make contact with the bulb on either side of the board.
Best4x4
Vidor, TX
On late 07 and up it's as easy as just popping the panel free disconnecting all the wiring harnesses and then just taking a small flat head to twist the bulb out. Earlier 06/07's require a little more work to get the switch pack free from the door, but it's not that much harder.
USMC_TOP
Muir Michigan
Speaking of interior lights, is the headlight switch area suppose to light up @ night with everything else inside the cab?
Best4x4
Vidor, TX
Yep it does, bulbs are strange T4's with the bases being about an inch long on one and maybe half an inch on the other.
