evldave
- somewhere west of north
ok, so decided to lightly use my compressor to clean a bunch of the dust out of my engine compartment. Now I'm throwing the P2176, P2101, P0030 and P0035 codes and the truck goes into 'limp' mode. I can clear them while the truck is running and about 50% of the time it works and the truck drives fine. Sometimes it takes 3-4 clears before the codes actually clear and it'll drive fine.
I checked and cleaned all the fuses and relays in the main fusebox, just in case one of them was loose.
P0030 code is Heater Control Circuit Bank 1 Sensor 1
P0036 code is Heater Control Circuit Bank 1 Sensor 2
P2101 is Control Module Throttle Actuator Position Performance
P2176 is Minimum Throttle Position Not Learned
I'm thinking I might have either blown loose a connection or got dust somewhere (TPS maybe?).
As a note, the truck will start and run fine when cold. This only happens when it's partially or fully warmed up.
Any ideas?
Any ideas?
