Paladine71
ΜΟΛΩΝ ΛΑΒΕ
- Tallmansville, WV
Bugout bags / emergency packs are based completely on your own needs and plans. A cardinal rule is that you should NEVER let someone else choose what goes in it for you. Packs prepared by stores will almost always contain things that you don't need, not contain things that you do need and most of the gear is of the lowest quality while charging you a premium price. You should always pack your own bag based on your situation, pack quality equipment and know how to use every item of it thoroughly (that is the most overlooked part).
Your first priority should be tools that you can't easily replicate or produce in the wilderness. The most useful of these, and a place that you want the highest quality, is a knife (at least one). Defense is not the primary use for a knife, it will be your most used tool. You want to choose carefully here. Some common uses:
- Cutting material (plants, cordage, etc.)
- Chopping wood (yes, you read that correctly)
- Eating and meal preparation
- Tool making
- Defense / Hunting
- Field Dressing Animals
- Fire starting
Here is my personal choice, the Becker BK-7 (with the BK-13).
This knife has a full tang, is incredibly strong, big enough to chop wood, small enough for dressing game (the smaller BK-13 helps a lot here), etc. It is built to last through the harshest conditions.
http://www.amazon.com/Ka-Bar-Becker-BK7-Combat-Utility/dp/B001IPMG8K/ref=cm_cr_pr_product_top
- Tool making
- Defense / Hunting
- Fire starting
