H3 Backwoods H3 build!?
backwoods
independence
Got my shackels on today. Also got a start on my painting and applying the HUMMER decals on all my light covers... I start by sandin/scuffing off the brand logo with 400 grit sand paper and then clean the surface with wax and grease remover and proceed with 4-5 light coats of your desired color. After your paint is dry and no longer tacky you are ok to apply your decals make sure you press put any air bubbles out make sure you keep the surface clean. If surface is clean you can apply your clear coat.i like clear coating over the decal for added protection and it wont just peel off later on
backwoods
independence
i have my 6 KC Hilights on my roof that i l have to do and i dropped off my OEM offroad light covers off at my cousins sign shop to fill in the imprinted "Hummer" so they will also match the rest
Really like the logos on the lights i might do it on my lights !!
ReconH3
Guardian Angel
Raleigh, NC
Looks awesome with the custom Hummer light covers. I like original ideas like that. You should color match your grill.
"Ex Umbris Venimus"
Sent from my iPhone
backwoods
independence
"Ex Umbris Venimus"
Sent from my iPhone
Yea i have been debating that mod just couldnt make up my mind between birch white or black
ReconH3
Guardian Angel
Raleigh, NC
I would personally do white, because black is the common thing to do. It would make the brush guard and light stand out better. Plus it looks soooo good on a white H3. More than in any other color.
"Ex Umbris Venimus"
Sent from my iPhone
Nacho
Now with Chese
With all the gear you have on the front I like the look of a black or Gray that matches the front plastics over a white grill.
Here are a couple renderings to help you decide.
Id get 2 cans. I have a white grill that i got off of craigslist a while back that im probably going to put on next week too. I feel that the white grill gives it character, especially if you already have a black brushguard and other black accessories up front.
I think 2 cans would be the minimum. There's more area than you think, plus you'll need to do a couple coats.
You going black or white?
>Sent from my Secret Phone Shoe using Tapatalk<
backwoods
independence
White i already have some clear coat so i will have Oriellys mix me up a couple rattlers
I didn't know that they could do that! There aren't any O'Reilleys around here to my knowledge...
I'd say let us know how it turns out, but I know you will. :wink:
backwoods
independence
back when i had my stang i painted alota stuff upwith that stuff
She was the redhead traded her straight up with my choice of tires for four corners....i had just repaled brakes on it and serviced it the week before(im a tech at a dealership)
backwoods
independence
Also i hauled my 10gauge 4x10' sheet of steel from the place i bought it from to my parents shop to begin the marking out and cutting process be patient with me on this as i have to do the welding over my lunch hours the first pic is my mock up
backwoods
independence
Ordered my paint color matched today will be here tomorrow is it hard to pull the grille off?
backwoods
independence
Got the lower bumper portion all cut out tonight start the welding process of that tomorrow over my lunch hours for till its complete
