6l80e Transmission swap
Iwillnc
In the past the ideas of swapping the 4L65e to the 6L80e were rightfully met with resounding No’s, and don’t try. At recently as 6-7 years ago this swap was a $7,500-$10,000 endeavor.
From what I’m seeing that’s changed dramatically in recent years. Swaps from $2,000-$4,000 seems very possible mostly depending on price paid for a 4wd 6L80e trans.
Wiring harnesses/stand alone TCM can be bought for less than $1,000 that will mate your trucks system to the new TCM to run the transmission.
The transmission is 0.021 inches longer, this should be nominal enough that the existing drive shafts should be able to handle without trouble. Likewise the H3 guys have already proven that the existing mount location of their 4l60e matches the locations on the 6l80e
That leaves the last piece of the puzzle, mating the splines on the trans output to the transfer case. I do not know exactly what the spline count is on either side, I also don’t know if the 03-07 vs 08-09 share the same transmission spline counts.
- On one hand if they do share the same spline counts then the 6L80e should be a direct swap.
- On the other hand it may be possible to buy the transfer case input shaft for an 08-09 and make it work on the 03-07 transfer case. I am not aware of how the electronics on the transfer case changed from 07 to 08 but simply swapping the complete 08-09 transfer case may not be feasible.
This leaves the why, there are many reasons to do the 6 speed swap.
-Improved step ratios mean smoother shifts
- Better 1st to get the truck moving and for off-roading
- Two over drives for improvements on fuel economy.
-Simply put the truck feels a lot stronger and durable with the stronger 6l80 design, it’s no secret the 4l65 is a small unit that’s inadequate for the weight and mission of the H2.
-Capable of holding up to 500HP and about 10,800 lb tow rating.
-0-60 would be greatly improved as more ratios are available as well as significantly quicker shifts.
I may start looking into this much more, the stock trans (with stock sized tires) is good for about 120-140k miles which is inadequate in my opinion, it should really be triple that which I think the 6L80e can do.
I have a date set to get my truck regeared later this month, following that I plan on going to PCM of NC, which I am routinely near, and the H3 guys will know, to have the truck tuned and plan on talking through this for more ideas.
For the price and gains it’s a real no brainer. I might have also forgot to mention I have a spare H2 transfer case laying around which would be helpful.
The only other road blocks I am seeing is complete walk through on these, which will mean some learning curve will exist, most Corvette and Camaro guys talking about trans conversions are going from 6L80e to 4L80e to hold their 750HP setup. And then most of the guys doing 4L60e to 6l80e are doing 2wd setups which, while closer to the money, still leaves some questions.
Iwillnc
Let’s make it clear, this is a thought, this is not yet a journey, my truck has an appointment for gears in two weeks and I hope that makes a big difference with drivability.
I have many other projects in line before this becomes serious. I’m just lucky enough to have a spare transfer case laying around.
The H3 guys have already done this swap several times and they face a very similar battle
Though if someone wanted to donate a free 2007-2009 4wd 6L80e I could push it up
If I had a spare truck I would be all over this but putting my truck out of service for a couple months would leave me with withdrawals. I have a much nicer and newer car with an engine bigger than the 6.0 in the H2 and less than half the 0-60 but I always fall right back to my H2. I love this truck like nothing else I’ve ever driven.
atvspeed4
massachusetts
For an h2 I'd do the 4l80e with the six speed conversion and lower first gear. There is a company that already makes the 27 spline output 300m for the 4l80 and the cross member to do the swap. I have a 2008-2009 brand new input shaft/ planetary 32 spline at our shop we never used as it was too short to swap into the h3 case. Was pretty expensive piece to get but should fit the earlier h2 tcase.
I have a 6 speed swapped h3 and I'd honestly rather have a built 4l80 in a h2. My business partner looked into swapping his 2007 h2 and due to the different pre generation electronic architecture used on 2003-2007 h2 the swap was not going to be straight forward to have full functional integration of dash display, shifter, and 4x4 controls. He went with a fully built PATC 4l65e and had been thrilled even pulling heavy enclosed trailer on 37s in overdrive
Iwillnc
I respect the 4L80e for being damn near invincible, but the gear spread is narrower than the 4l65 we have, first is lower and not as deep as our first, and overdrive isn’t as low as ours.
I did look at the 4l80 6 speed conversion you mentioned, as I was not aware it existed, but I have to say I’m pretty disappointed in that too, it doesn’t improve on the 4l65e on either end but rather puts more spread in the middle. And all of that at a very steep cost.
Then you have to have both driveshafts recut etc.
I do see what your saying about the 6l80e electronics, it would take some time to figure out how to get certain systems mated, speed lockout on transfer case as you mentioned.
I’m really hoping my gear swap in two weeks makes big improvements on the driveline feel. Frankly with the current gear ratios actualized the driveline feels like glass, I’m afraid to pound on it for fear of blowing the trans. And that’s only with 35.6” tires, I’ve seen several people running 40”s on the stock 4.10 and I don’t get it.
The 6L80e has really nice ratios with a deep first and two OD.
Iwillnc
I guess the other option as you mentioned would be a built 65.
I have blown two 3-4 clutch sets in a 4l60e and 4l65e, it would be nice to fix that issue.
