3600lbs of sand bags in the back of the h3 (pic included)
Kyle
Santa Clarita, CA
okay, i was told 700 pounds was the max weight for cargo area with the rear seats folded down. But today i had to get sand for the back yard (50lb bags) 72 bags total, they all fit, and the rear was sagging pretty good, but i didnt feel any loss of power or and rubbing or hitting in the rear. Whats the heaviest thing you guys have put in the back? will post up a picture from my phone!
Kyle
Santa Clarita, CA
Sent from the top of a mountain in my h3
Kyle
Santa Clarita, CA
yea, on top of the rear seats folded down and in the main cargo area, i didnt think to take a photo of all the bags in the back at the time, i do have a photo of the bricks i hauled last week, that was only like 3200 pounds. ill post that up!
That's a good example of using the wrong tool for the job. Get a truck or rent a trailer. It's not worth tearing something up or getting hurt over it. I would not have wanted to be in the driver's seat if you were in an accident with nearly 2 tons of cargo unsecured behind you.
I'm thinking those springs, at least when the H3 was loaded, had that wonderful reverse bend at the shackle.
cbetts
NERD!!!
Rancho Palos Verdes, CA
:whaa:
Yeah, I think you were past my comfort level . . .
If you had to take some kind of evasive action, things would be ugly. If you have to use your truck, rent a trailer.
Death from behind.....
jakesz28
Cabool MO
I have had 12 or 14 bags of Sack-Crete in the back of mine. So maybe 900 pounds. I was impressed with the way it held it. Its far from a 3/4 ton truck but compared to the Dodge Durango I had which would have been sagging. My rear springs are bending the wrong way after the second leaf.
Kyle
Santa Clarita, CA
well it would have been passed my comfort level too if i had to go more than half a mile with it all loaded up like that. Home depot is literally right by my house.
I learned that lesson a long time ago when driving an Econoline cargo van with an unsecured 55 gallon drum of oil in the back. Had to stop short when I was cut off by another car. That barrel of oil came flying up and luckily it wedged between the seats, instead of crushing me in the driver's seat. It ended up bending both seats.
Actually...a reverse bend in the leafs at the shackles is totally normal. Overloaded or not. Many of us have this same issue and it results in a net loss of 1.5"-2" of rear ride-height. If you've leveled your H3 by raising the front...the sag is even more noticable, due to the extra weight shifted rearward. The H3 has a very delicate front-to-rear balance, and it doesn't take much change to feel a difference in handling.
So far, I think Speedy has the best fix. He grabbed a pair of junkyard leaf packs from a 2500 Chevy truck...took them apart...and inserted the longest leaf into the H3's spring pack. He installed it into the 2nd position, right up against the main leaf of the H3. This is a much better idea than a traditional add-a-leaf which gets installed in the overload position (lower in the stack). The traditional add-a-leafs don't do much to support the main leaf near the spring eye, which seems to be where the problem is.
Another nice thing about this mod is that the full-size Chevy springs are drilled off-center, just like the H3's springs. You'll find that any standard add-a-leaf you buy will have the hole equal distance from either end...and that doesn't really work with the H3. I'm currently running ebay add-a-leafs and I re-drilled mine to position them correctly with the rest of the springs. Trust me...you don't want to drill spring steel!!! They work good but, the next time I have stuff apart...I plan to swap-in some Speedy springs.
P.S. Notice how your leaves seem to be "de-laminated" near the clamp? They should be pressed together nice & tight, and you can clearly see how the main leaf has gone flat, while the ones below it still have their arch. That's the problem you need to fix! Adding the full-size second leaf helps this tremendously...plus you can tighten up that clamp when you put it back together. Maybe even add additional clamps?
Is it just me or is that a picture of a load of landscape wall blocks not bags of sand??
Dang computer must be acting up or the sand got wet?
No loss of power huh?
If it was that close to HD why didn't you make several trips?
Kyle
Santa Clarita, CA
I forgot to snap a picture of the sand bags, but i did take a photo of the cinder blocks in the back when i transportting those! and there wasnt a dramatic loss in power but you could tell there was stuff back there. and i did make multiple trips for the cinder blocks but not the sand bags
chad
florida
i would of done the same thing and been like wow this truck does good being way over load limit:giggle: i wouldnt have thought twice about bending the springs as long as the tires wherent rubbing while driving! and one trip is easier than several! but now thanks to your thread i know not to overload my truck! thanks, you may have saved me lots of money in the future:thumbs:
