I need one that was known to be good. 2.64:1 or 4.03:1....doesn't matter. Unfortunately, the mods I got planned will either work...or render the t-case useless! -haha.
The basic idea...
I want to modify the 4HI-Street mode inside the case, to make it 2WD (rear output only). This mode uses an inline differential that is much like a single-track axle diff....except it all operates on the same centerline (rather than 90-degrees apart, like an axle). If you've ever messed with single-track diffs, you know that the wheel with the least traction gets all the power. The Hummer t-case works the same way. If you've ever watched a Hummer get stuck in the mud...you'll see that the end with traction quits spinning, and all the power goes to the other axle. This is also why H3's don't move with a broken front axle. The diff inside the t-case thinks its spinning, and takes all the power off the rear output and sends it to the front. Its touted as being a 60/40 split but, it does vary all the way to 0/100 if conditions necessitate it. This variable split between the outputs is what makes the H3 so driveable in 4HI-Street. In tight corners...it varies itself so you don't feel the binding that normally occurs in a locked 4WD vehicle.
This variable device is entirely mechanical. There are no clutches or springs. There are no sensors or viscous devices. The variable dohinky assembly (or VDA) has a basket with a sun-gear and planetary gears, that vary the torque output going to each end of the vehicle. What I propose doing is taking the VDA apart...machining the teeth off of the front drive gear...then welding the rear drive gear so it is permanently connected. I am hoping this will result in converting the 4HI-Street mode to 2HI-Locked. When done...the 4HI-locked and 4LO-locked modes will hopefully be un-affected. Then when you hit the 4HI-Street mode...the fork activates the VDA like normal...however the teeth are gone from the front drive of the VDA, and the rear drive is welded solid to the VDA. Thus...2WD mode. Obviously, this means nothing to 99.9% of H3 owners but, it would be great for us with solid front axles and locking hubs. It would essentially be converted to a traditional 3-mode 2HI-4HI-4LO case.
I'm 99% sure there will be no electronic intervention with this mod. ABS, Traction Control, and Stabilitrac are all governed by computers, and enforced by the braking system. The self-sensing front/rear torque split of the t-case is entirely mechanical and dumb. It is not controlled by any electronic source that I can find. Best of all...this will require no levers, fabrication, or swapping. Its a mod that is entirely internal to the t-case and it would look and act just like stock from the outside. Given the choice...I would gladly trade the torque split 4HI-street mode, for a completely disconnected 2WD front axle. I have evolved (or de-volved, depending on how you look at it), to using my truck for two purposes...(1) driving around on the street or (2) full-on off-roading. I want 2WD or I want 4WD-Locked. Period. I simply do not want a full-time 4WD mode anymore.
The big concerns I have with trying this are...
Will the front output (driveshaft) remain static while the rear output is turning at 70mph? The idea is that the front diff, driveshaft, and output from the t-case are all motionless in 2WD.
If so...can the front output of the VDA survive this free-spinning situation for extended periods of time? This depends on what sort of bearing situation exists inside the VDA. No doubt the stock case is designed for occasional speed differences that occur between outputs, during the range of torque splitting (For example: 60/40, 70/30, 80/20, etc.). But, I'm not sure its designed for a 12-hour interstate trip with the font output completely motionless and the rear output screaming away at 70 mph (100/0 split). Possibly staying this way for months at a time.
Only one way to find out.
