HUMMER INVESTMENTS
[o O IIIIIIII O o]
- Black Hawk, SD
Well now I've gotten serious about selling the H1. I *really* want to get my hands on the 04 that I have my eye on.
Well I think it is time to put my H1 up for sale. We are interested in upgrading to a 2004 or 2006 Hummer H1, and a very nice 2004 Hummer H1 has come up that I really want, and was offered to me about 2 years ago, but I did not have the money at the time.
Here are some specs on it:
Vin: 137ZA8435XE184939
1999 Hummer H1
6.5 TD
2" Custom Suspension Lift
Lowrance GPS
Cooper Discoverer STT tires
Humher Roof Rack- Also has an extending ladder that comes out of the rear of the roof rack.
Cepek Rims with Cepek quick disconnects for the CTIS
Piaa Lights
LED dome lights
I *believe* that there are 4 Piaa 520 lights and 6 Piaa 2100 lights.
It has LED turn Signals, LED side marker lights. There is possibly a problem with the ground for the passenger rear side marker lights. The end of it lights up but not the whole thing, witch is a pretty easy fix so I've heard, but never did think much of it. With the 2" suspension lift this will enable you to run up to 41"/ 42" tires, but you'd still need to upgrade to better halfshafts.
We just took it in for an alignment today so it should be good to go. CTIS works flawlessly. The front dome light does not work in its current stage. The reason being that I havent fixed it is because It is already so bright with just one lit up. Other than the the rear side marker light and the front dome light it is in perfect shape. It does have the new block and was replaced under warranty.I just got the alignment done and put on a new Pitman and Idler arm on the driver front. The other side's are in good shape, so they should be good. I should also add that it has 63,753 miles, or about 64,000 Miles..
Located in Rapid City, SD
Update*
Included in the price is these spare parts:
1 Leece Nevill Starter Motor
Lot of AM General thermostats
Lot of 3 brush guards
1 AMG Volt Meter
2 tan seat covers, arm rests and head covers
1 AM General 5.5" speaker
1 AM General Tail Lamp Assembly
1 Interior Door Handle
1 Input Gear Assembly
1 AM General Fuel Gauge
1 stainless steel ctis braided hose
1 Exhaust Heat Shield
2 Runflat/Beadlock Assemblies
2 Radiator to Hood Foam Seals
1 AM General Temp Gauge
1 AM General Heater Resistor Circuit & Plug
1 AM General Aluminum Wheel
1 AM General Splash Shield
1 lot of AM General Gaskets
1 lot of Halfshaft Boots
1 16.5" wheel (backside)
1 rear jumpseat & seatbelts
1 Warn Front Winch Bumper
2 Front Non Front Winch Bumpers
1 6.5L AM General Oil pan
1 AM General Radio Antenna
2 AM General Heavy Brake Yokes
1 Power Mirror Switch & Wiring Harness
1 Set of "Diesel Fuel Only" Signs
1 Vacuum Pump Solenoid
1 Engine Block Heater Cord
1 Door Arm Rest
1 Lot Exhaust Gaskets
1 Lot Clampnut Hub Parts
1 Oil Pressure Gauge
1 Heater Control Valve & Connector
1 Transmission Pan Gasket
1 Lot Exhaust Clamps
1 Lot Intake Manifold Gaskets
1 Lot Alignment Shims
2 D-Rings & Brackets
2 Door Lock / Latch Mechanisms
1 Geard Hub Output Seal
1 Lot of Seat Belt Parts
1 Fuel Sender Unit
1 Power Steering Reservoir
1 Keyless Remote Receiver Assembly
1 Seven Pin Trailer Assembly
1 SMA Aluminum Dash Kit
1 Upper Control Arm, Bushing & Bolts
1 Status Box Assembly & Wire Harness
1 Fuel Injection Pump
1 Water Pump
1 Lower Radiator Tube
1 Pair Valve Covers
1 Lot Bumper & Frame Brackets
1 Lower Splash Shield (interior plastic)
1 Front Grey Headliner
1 Tan Front Window Trim Piece
1 Burlwood Dash Kit
1 Grote License Plate Replacement Light
1 Lot of CTIS Covers
1 Glow Plug Controller
1 Ignition Switch & Key
2 Automatic Window Motor & Assemblies
1 HVAC Blower Motor
1 Lot of Vent Line Hose
2 Two Inch Suspension Lift Spring Spacers & Front Springs
1 Window Glass Gasket Kit
1 Lot of High Pressure Hoses & Fittings
1 Lot Exhaust Wrap
1 Lot of Engine Gaskets
2 Heated Windshields
4 Brake Rotors
1 Front Brake Caliper Core
1 Lot of Drive Shaft Yokes
1 Lot of Wiring Harnesses
1 Fuel Sender
2 Differential to Brake Rotor Output Flanges
1 Lot of Tie Down Straps
1 Upper Ball Join
1 Lower Ball Joint
Here are some pictures of it ( these are pictures after installing the 2" lift kit ):
Colorado Pictures:
Asking 50,000
1999 Hummer H1
6.5 TD
Lowrance GPS
Piaa Lights
LED dome lights
Update*
1 AMG Volt Meter
1 Door Arm Rest
1 Fuel Sender Unit
1 Water Pump
1 Pair Valve Covers
1 Burlwood Dash Kit
1 HVAC Blower Motor
1 Lot Exhaust Wrap
4 Brake Rotors
1 Fuel Sender
1 Upper Ball Join
1 Lower Ball Joint
Colorado Pictures:
Asking 50,000
