06 Hummer 3.5 I5 RPM jumping around when Idle
06yellowh3
Rock Falls, Illinois
I have noticed over the past week or so that when my hummer is in idle (like when parked in a parking lot or in my garage and stopped at a red light), that the rpm gauge bounces around and when out of the vehicle I can hear the engine changing rpms. I just had my serpentine belt changed and my thermostat a couple of months ago, but other than that I haven't done anything else to the engine besides change the oil. Do you know what could be causing this problem?
Is the change in RPMs that of rising RPMs or lowering, like it is almost stalling? What range are the numbers on the gauge?
ArtHummer
Gaithersburg/MD
I just cleaned the throttle body a couple months ago and installed new spark plugs in march. and there are 127,486mi on it
Did you cleaned the MAF sensor?
Other reasons. bad sensor. bad plug, bad coil, water got in to the spark plugs(that happens sometime when you wash the engine)
n8rfastback
Omaha, NE
Just remove it with those two torx screws, add spray it out really good with maf sensor cleaner. I would try to clean up those coils somehow or just replace them.
Sent from Nates phone...
