I have an 03 h2 that is having on going t case issues. I have owned truck for 5 years it has been great I now have 220000km on it. At 210 the factory original t-case lost rear out out shaft bearing and destroyed the housing. I replace transmission and t case factory gm parts right from dealer came on pallet they just had to bolt it in... Now I'm 10000km 15 months later and the bearing is shot in the rear out out shaft again.. I caught it this time before destroying the case.. I will give low down on truck repairs
I have owned it for 160000km. Well maintained I'm picky
all repairs in last 10,000 miles
- front away bar linkage and bushings
- ball joints and tie rods
- steering stabilizer
- power steering pump (x2)
4 shocks
new brakes
steering stabilizer
rear transfercase output shaft seal(x3) before it went boom
transsmission ( gm replacement)
transfercase ( gm replacement)
tail shaft / u joint ( once before replacing t case and then at time of replace
air suspension to spring kit
rear sway bar bushing and linkages
plug and wires
35.12.5 20 tires
The factory t case over the 5 years went threw 3 rear out out shaft seals before the transfercase bearing failed.
im going to investigate it a little closer in the morning sinething to me is wrong from either tail shaft ( maybe pre placed with wrong shaft , or out of balance drive shaft but there is no vibration since rebuild until now
or something changed in alinement after removing air out of the rear.. Any ideas or replacement parts suggested would be greatly appreciated
4 shocks
new brakes
steering stabilizer
plug and wires
35.12.5 20 tires
