Congrats on the new to you H3.
Yes, let's see what constitutes that lift. It's likely torsion bar keys and bump stop extenders. If you don't know where the torsion bar keys are, follow the long rod (the torsion bar) coming out of the back of the lower control arm of the front suspension. At the aft end of the torsion bar, it goes into a "key" that's held in place with a large bolt. Easy to remove, but you'll need to get the original style keys.
Radiator - OEM ones are not that much more than standard aftermarket and they are built better. Yes, people have issues with them but often closer to 100,000 miles. The cheap ones I've had fail earlier, and I haven't seen the benefit of a $600 radiator for my H3.
Change all fluids: oil, front and rear diffs, transfer case, transmission (at least a drop and fill with new filter), coolant, brake fluid, power steering fluid. New spark plugs (AC Delcos are on sale at rockauto.com and you can get a $3 per plug rebate on iridiums from AC Delco). New serpentine belt. Maybe new fan clutch.
New air filter. Pull off air box on top of engine (wait, is this a V8 or I5) and assuming it's an I5, check the short rubber hose at the back end that goes from the valve cover to the airbox (do this during spark plug change). If that hose is super-soft and pliable (or super hard), replace it.
Check the radiator hoses for pliability and wear. Check water pump for excess play and/or leaks. Check front wheel hubs for excess play.
CV boots - is it a tiny leak in the middle of the boot? Clean it with brake cleaner and seal with RTV. If replacing, I highly recommend OEM but they are much more expensive than aftermarket. Put in new axle seals (OEM) at the same time. It's typically easier now to replace the CV axle than just the boot.
Depending on your comfort with wrenching, most of this could be done in your driveway. If not, be careful as I just gave a HUGE list of things to check and a shop could take you deep.
Your blinker fluid and muffler bearings are probably fine
