- Way up north, UT
After some research and pondering, I think I'm going to go with rear air springs to help with loads when offroading and hauling. Since this is my daily driver I'd like it to handle well when empty (and since the road I drive for my commute is worse than a number of dirt roads I've been on...) but be able to handle heavier loads when going camping and offroading. I think air bags will give me the flexibility I want for this, and cost less than having custom springs made for me.
That being said, I'm trying to decide between the Air Lift 59563 kit that Hunner uses and the Firestone 2190 kit I've seen others using that goes in place of the bump stops.
Positives of the Air Lift is it doesn't require as much modification and it retains the bump stops.
Positives of the Firestone is it can use the Daystar cradles to allow full droop.
Negatives of the Air Lift is you have to move the brake line bracket so that it doesn't accidentally slice open the air bag as Hunner found. It also doesn't seem like it allows full droop, but I'm not sure.
Negatives of the Firestone is it eliminates the bump stop so it becomes the bump stop, not sure how risky this is. Because of this it also requires greater modification to the frame.
The Air Lift is the cheaper of the two, but not by a whole lot.
Thoughts?
Thoughts?
