2017 Moab Black Sheep April 16-21
Are those all factory bolt on Alex?
90% factory. It's not a kit with all of the required factory parts. Each one had to be individually ordered and a couple of the required brackets were not available so Steve made them. Also, his H3 did not have the mounting holes for those brackets that a South African H3 would have. He still has to wire it up and it may need some PCM work to make it integrate nicely.
Gotcha, looks great. They seem very narrow (in height front to back) so they fit the H3 nicely, makes sense since they were factory! Lol...I'm interested in those. Making brackets is no problem and I would run them off a switch like I do with my smaller ones I have now so I can turn them on and off as I please. I'm going to have to look into those.
On the SA model, Each fan is controlled independently off the pcm. One for low temp setting (the smaller fan) and the other at the higher temp setting.
For an E67 pcm on the alpha you can easily find a pinout diagram for the pcm that lists the pinouts for the low speed and high speed. Once you connect each one of those to a relay (its a must or you will burn the pcm) you need to enable the feature in the tune (fan control logic using hptuners/efi live).
The logic is also contoller by AC pressure. The Alpha has a pressure sensor and based on that the fans will work once a certain pressure is reached.
speedy
Sir Welds a Lot
Dayton NV. Battle Born!!
I still have a couple of things to finish up:thumbsup:thumbsup
About six bolts and a couple of fittings? Heck you should be done by noon!
I was curious how far along that project was.
Highatop
Florissant, Co.
Looks like a big group this year, we are getting excited and it can't come soon enough. The only change for us will be a 4:1 Tcase. See you all soon...
Woodtick
Ilanoid, UP MI
The wife voted down Moab. We are going to Naples FL and the Everglades . One day I will make it out there. I will post some swamp buggy pics.:cheers:
jakesz28
Cabool MO
Well, i have a business trip overseas again. Right before this, hopefully i get back as scheduled April 9th. I still have not installed the rear locker and would like to install it for this trip.
H32NV
Golden, CO
I will have 5 in the group. Will get to Moab Thursday Apr 20 at Noon, leaving Sunday AM. Can't wait to see everyone.
Bringing: tools, tie rods, half shaft, Teryx 4 seat UTV
Just did new 35" MTR's and Moog problem solver tie rods, both sides.
Neo
Badfish
Brookings, OR
right on buddy
I really want to come down for this. I might be able to swing a day or two off of work. I'm using the majority of my vacation time to go to New Hampshire during June though.
