- Tardville
Knock on wood...my 08-5cyl has been rock steady since day one but, there are WAY too many discussions about H3 cooling systems. I know Alphas run hot. I've seen it on numerous H3's so I think there is some merit to those complaints. But not the 5-cylinder. No way. There should be plenty of cooling available with the stock system.
There seems to be a culture among Hummer owners that more money means more performance. And its never been more pronounced, than it is with the cooling system. Seriously...there are some crazy ideas & suggestions floating around about how to solve a hot-running H3. Everything from cutting holes in the hood, to adding fans, high-dollar aluminum radiators, and messing with ECM settings. Its quite entertaining to read about these mods but, its also sad that some people buy into the b.s. and end up blowing hundreds of dollars on their cooling system for virtually no reason at all.
Unlike the rest of the H3...the cooling system is super old-school, and its not that hard (or expensive) to get it working correctly. I honestly don't understand the need to "get tricky" with it. You can replace the ENTIRE cooling system for very little money, and return it to factory spec. and it should perform perfectly. If it doesn't...something is wrong. No amount of radiator, e-fan, clutch, pcm tuning, thermostat, blah blah blah is going to fix it. If it does...then you are most likely masking the real cause of the overheating, rather than simply fixing the original problem.
