GreatDaneHummer
- Chicago
Ok guys, lets see if as a collective we can solve this issue with my cooling. Here are the symptoms auto Dr's.
- Cracked radiator with over heating was the starting issue.
1.) Replaced radiator with CSF all aluminum OEM replacement.
2.) With everything taken apart, replaced water pump with:
http://www.autozone.com/cooling-hea...-3-7l-mfi-dohc/536555_381126_0/?checkfit=true
- Truck over heating with no fan kicking on. Just spinning at idle RPM. Over heating as in needle to the top RED. Not the 3/4 miss understanding many of us deal with.
3.) Replaced fan clutch with:
http://www.napaonline.com/napa/en/p/TEM271306/TEM271306_0224185585
I did use 50/50 OEM spec'd coolant.. When sitting in traffic my engine again over heats with the AC going from cold to mild air. As soon as I am moving you can hear the fan running like a MACK truck making same noise and the temps drop down to the center half way mark within 1 min of moving. I spoke with 4speedfunk last night (CJ) and he thinks there might be air in the water pump and system that is sitting around the water pump at idle causing it to over heat not actually pumping coolant. I did not have it vacuum filled with coolant after everything changed. I just kept topping off the coolant reservoir as it settled during operation. I am to the point of just changing over to an all E fan setup due to frustration but come on... this should be working great. I should not be having such issue with cooling with all these new parts. The thermostat was also changed 5 months ago. Is there a fuse or something that can go bad or relay that tells the fan clutch when to kick in?
