H3 Need Help Identifying Part
ZoroTheGreat
La Verne, California
I was wondering what the clear plastic lenses over the headlights and turn signals are called. They're the ones that are mounted with tabs on all four sides of each lamp. I wanted to try and do a smoked look and wanted to know where I could pick up spares if I don't like how it turns out. Here's an example assembly.
http://www.amazon.com/gp/aw/d/B0048...C_UL100_SR100,75_&refRID=1SBZ59M2XE768J3NST75
Any help identifying this part and where I can buy it is greatly appreciated.
Ghostbuster
Don't smoke the actually headlight! It will reduce output! You know how well you see at night while driving.
When I see someone with smoked out headlights I just laugh.
I have set of the complete turn signal assemblies that you can have if you pay shipping.
ZoroTheGreat
I should have clearified that I was only planning on smoking out the turn signals. Thank you for the offer I'll look into that. I just wanted to figure out what those lenses are called so I can buy them.
ZoroTheGreat
CaddyStrophic
I'm currently retrofitting my headlights and replacing my corners with LEDs. I've taken everything and the previous comment is correct. It's sealed together and you don't really want to mess with it.
Just buy replacements and smoke them and bolt them in.
(Currently under construction.)
Burnoffski
Virginia
Looks pretty sweet!
Romeo
New York City
What LEDs corners are those and how did you get those headlights to work? Send build thread if you have one, thanks. Looks good btw!
CaddyStrophic
H322
Looked through your build may have overlooked it. But where did you order the headlight replacements? How was the install? Thanks
H322
Thank you for response how did you mount them? How well do they work? I like the way they look a lot wouldn't mind doing this myself.
CaddyStrophic
If you go under the builds section, I have a thread there under "Devil's Night". The headlights aren't completely finished,yet.
The passenger side is pretty much done, and the driver's side housing is being molded right now.
But, yeah. The pics in my build thread should show what all needs to be done to mount these. (Spoiler, IT'S A TON OF WORK.)
