- Way up north, UT
So I just had a thought, and wondered what others thought of this, but it seems like it'd be pretty simple to convert our tow rings to be quick-disconnect-able so that you can hook straps up to them without needing another chunk of metal (shackle).
It seems all you'd have to do is remove the nuts off the bolts and drill the bolts to accept a pin, and then just use a pin to hold the bolts in place. It's not like you're pulling on the bolt that it'd need a nut to keep it in place, the D-rings fit pretty snugly with the rest of the assembly so side-to-side motion isn't a concern, all the pin would need to do really is keep the bolt from just falling out while driving around and whatnot. Biggest concern I can think of it'd make it easy for someone to steal the D-rings, but you could just chuck them in your recovery gear bag when you're not on the trail.
So, any other ideas as to why this isn't a good idea? I honestly can't think of ever seeing this done before.
