Vents seem to blow harder on passenger's side than driver's.....
2007HummerH2
Maine
I know there are a lot of problems with the heat/a/c controls with our H2's. However I haven't figured out the problem I have. Everything works for heat, a/c, and where it blows out of.
My problem is when I have it on the feet and vents the passenger's side blows nice, but the driver's side has hardly any air from the vents. Not sure if it's an actuator motor not working properly or a flapper is getting stuck for the direction of the air.
Any info would be great as the temps are around 0 here and some heat on my side would be nice!
Is that the name of your gf now? Vents?
Either way I don't care if it's left side or right... As long as she's a blowin'
skeptic
Orygun
What's funny is I was thinking something similar. It's not your vents it's your wife/gf blowing hot air from the passenger side. Not you personally of course, just the first thing that popped into my head.
Sorry, I know that doesn't help. I don't ride in the passenger side so no idea whether there is a side to side difference in airflow from the foot vents.
glpd74
Mine is similar also. Dropped off mine to have it looked at...il post up what I find out.
glpd74
Oops sorry. They forgot to check while they were replacing abs module. Mine still blows cold and warm so it doesn't bother me enough to take in just to have it checked.
jthompkins411
US
2003 h2 how hard is it to fix when you crank it up and it says that you're left door is not closed and your latch on the back of your truck is not closed. I don't know these are sensors but does anybody know what I need to do I don't want to have to take it into the shop and spend $3,000 to fix it.
jthompkins411
US
