Heater not working
Cash9300
Virginia
So I go out to the store tonight and I turn the heat on full blast and nothing happens it worked fine yesterday any ideas
CaddyStrophic
No experience with it myself, but I've heard there are these resisters that can go out pretty easily and cause your HVAC not to work. That or maybe heater core. Notice any smell of coolant or anything like that?
Cash9300
Virginia
No smell of coolant I do know there was a recall about the switches that operate the hvac I wonder if that or a fuse could be the guilty party
Odimus
Maine
Did you check the wiring or fuses? There is a current recall for the blower motor wiring...
Cash9300
Virginia
Well checked the fuses and none are blown so I guess my next day off will be spent at the dealership for the recall
650Hawk
Dealership can't fix the recall issue yet, as GM has not yet come up with a repair. It's still pending.
2nd2no1
Joliet, Illinois
I had a similar problem with the blower motor not working several years ago and the blower motor resistor is on the passenger side underneath the glove compartment. When i checked the resistor the plastic/wire had melted, I wiggled the wires and the blower motor turned on. I ended up cleaning up the resistor and applying electrical tape to the wires. I haven't any problems with the resistor or blower since then.
Boerwarrior
Sacramento, CA
My HVAC blower stopped working a week ago. Called dealer last week and they ordered a new harness to be ready for my appointment today.Just got back from dealer and they replaced the harness under recall warranty free of charge. Connector pins were burnt out. I will still have to take it back once the recall bulletin is released, but at least the blower is working again.
Sent from my SM-T320 using Tapatalk
Cash9300
Virginia
Couldn't get ahold of the dealership today cause of work going to call tomorrow and see when I can take it in
650Hawk
That's great. Most dealers are still charging for fixing this issue until the recall "fix" is released, with th caveat that owners may be reimbursed at that time. Nice to see a dealer step up and do right.
Cash9300
Virginia
Well I took it in today and was told I would have to pay 200 dollars to have it fixed and might get reimbursed after gm releases the fix for the recall so I just brought it home and now I'm waiting on the wife to get home from work and the parts store
Cash9300
Virginia
10 minutes of work to replace the resistor and it works 28 buck is a lot better then 200
Cash9300
Virginia
Well it's out again waiting to hear back from hummer customer service tomorrow
Cash9300
Virginia
I had to order the connector since advanced auto switched out the resistor and it wasn't the problem this time but hey I have a spare resistor
California
So, have you fixed the problem?
I'm browsing the site, hoping to find some info.......My heater is currently not working, but sometimes it comes on ok. Everything seems working fine, just there's no heat coming out. I had the recall replaced and fixed a year ago and all are working, but the last two weeks.
beadyeye
I'm having the same issue. My blower is working but all I get is cold air. Any ideas?
